Vacuum Container question...
I stumbled across some "DeRoyal Omni-Jug 5036-00 Large Volume 16L Suction Canisters" today at the freight auction. Is it possible you could use them as a vacuum container for impregnating wood? They are plastic. Short of hooking them up to my Vac pump and seeing them implode, how can I tell?
Re: Vacuum Container question...
Size Matters
Pull 28"hg on a tea cup and it's no big deal
Pull that in a 30 gallon drum and things will get exciting.
You said "suction" rather than "vacuum" so I suspect the objects of your affection may not take sufficient vacuum to do what you want. Vacuum/epoxy stabilization in usually done in pretty hefty containers from what I've seen.
I could, of course, be wrong ;)
Call them first
Dick Coers
but they sure don't look like a vacuum chamber to me. I hope to hell they don't ever draw a hard vacuum to remove blood from me during a surgery! Looks like you have some fancy flower pots to me.
John McGaw
Well, they are clearly made for hospital use for drain tube collection. The vacuum provided by the redundant vac pumps (per NFPA 99) in a hospital is usually around -22 inHg but this is in the manifold distribution system and would never be applied to a drainage container for patient safety. From what I can tell the absolute maximum vacuum allowed through the typical in-room regulator is 300 mmHg but looking at the gauges on them they indicate danger at about 1/3 of that range and no-go at 2/3. I think I'd just spring for a nice metal vacuum canister from Packard.
John in NM
Medical suction is usually pretty low vacuum, but even high vacuum is not a lot of psi (14.7 at sea level). So as Mark said, it depends on size - 14 psi over a large area will do some crushing, on a small vessel it is less of a weight.
Only one way to find out - try it with one :D
If it doesn't work, you could use what I use - an 8" PVC pipe coupling with an aluminum bottom siliconed on and a piece of 1/2" plexi for the top. I never did much stabilizing with it though, I was degassing resin & silicone for casting. I think one trick to stabilizing is to degass and then pull a vacuum on the wood+resin just short of boiling the resin.
They were free.....
No loss either way. I will either call the company or see what happens. Someone left them on a pallet I bought.
I looked them up on E-bay. Somebody wants $82 for a case of 4. I would be thrilled to sell them for that. I have 6 left. Gave 2 away.
My Packrat gene was twitching.
Steve jenkins
Occasionally I do a presentation for our woodworking club on using Vacumn for veneering and clamping. At the beginning I pull a Vacumn on a steel 55 gallon drum. It’s pretty impressive when it collapses with a loud bang
