Table Top Grain Line
Bill Marr
Gentlemen,
In making a Shaker candle stand, I used a quartersawn cherry for the 18 inch round top. In doing so I used a single board that I milled to 9/16ths, glued four panels together and cut it round on the bandsaw. After sanding the completed table to 600 grit, I decided to go with a boiled linseed oil and shellac finish. After applying the BLO I noticed that the top had a perfect line down the center where the panels were glued together. The line is not from glue but from the light hitting the grain that apparently is running in opposite directions. When you walk up to the table your eye goes right to it as one side is light and the other side is darker. This is very distracting and I feel the need to replace the top. I don’t normally make furniture however I did make a maple Shaker nightstand last year and did not have this issue. Perhaps I was just lucky when I glued the top panels together. Next time I think I’ll cut the ends off each panel and wipe with BLO to see how the light is hitting it before the glue-up. Is this a common concern. I would welcome your input. Thanks.
Bill
