Anybody got a big planer...Recommendations???
I am agonizing over buying a big planer. Started looking at a Grizzly 20" 3hp for about $2700 delivered with a spiral Head. It's out of stock, but they say it will be here in early April. Then I looked on E-bay and Craig's list and other brands. Can get a Grizzly on Craig's list for about $800 used with a straight head and can install a spiral head for about a thousand.
Now I am flummoxed. New one? Used one and leave it alone or used one and update the head? Fagedaboudit?
I appears that the Jet version is nearly identical to the Grizzly one, just different color. Is there really any significant difference?
Is 3 hp enough?
What say you?
Re: Anybody got a big planer...Recommendations???
Henry W
Barry: Far be it from me to try to talk someone out of a tool purchase... but
You have made it thus far in life without a large planer. Could you not purchase planing services when you need them? I know I could in Raleigh. I have only thought I needed a large planer once, and then found a much cheaper workaround. Sure it is not as convenient as owning your own, but I thought you were hemmed in a smaller shop right now? How you gonna fit a large planer in there?
Henry
Dick Coers
I vote for buy the used one, keep the stock head. I've been woodworking for almost 45 years. Made it this far without segment head, I think I can finish out without one.
big planer vs.
a roll of 36 grit for your Performax.
Hmmm,
2.5K v. $40 for occasional use.
Hmmmm
Yonak
Barry, if you decide to get a 20" planer, I don't believe I would consider anything less than 5hp. Also, if you can afford it, I don't think you would regret getting a spiral head. I've got straight cutters and the tear-out, especially in maple, is agonizing. I'm on the downside of my woodworking career so I won't be upgrading to a spiral head but, if I were closer to the beginning than the end of my career, I'd go with spiral or SHELIX technology.
Re: big planer vs.
John Foster
Agree, I have my 12" bench-top piece of junk hardware store planer for my narrow stock. For my occasional wide stuff, I put 36 or 40 grit abrasive in my 19-38 drum sander. I always thought when my crappie little planer died that I would get a good one, but if you have good blades in it, the finish is hard to beat because of the high cutter-head speed. For my level of use, I probably will just replace it with another 120 V. bench-top.
It's like dis, ya see.....
I have a pile of about 700 feet of white oak, sawed on a band mill and even more walnut and cherry. When I stand in my shop and stare at the rough pile of wood, I can hear my Dewalt lunch box planer whimper. Pretty sure that pile of wood will be the death of that planer.
And, it's slow and will only take about a 1/32" off at a time. So I am lusting after a big brother for it.
OTOH, for that kind of money, I could buy it several twins. Hmmm?
Right now I am leaning in Dick's direction. Get the older machine and give it a whirl, leaving the option of a new head open.
Jesse Cloud
I've never owned a big planer, so no data on the pro's and con's. I do have some experience with Jet vs. Grizzly on smaller jointer/planers.
I took a woodworking machinery maintenance class a few years ago and the teacher invited us to bring in broken machines for repair or new ones for setup. By chance a Jet combo machine came in the same day as a similar Grizzly.
The two looked eerily similar except for paint, knobs, and logo plates. But when we got down to set up time, the Jet was pretty much ready to roll out of the box. The Grizzly beds were not coplanar and one was way off from flat. The head was not parallel to either bed. The Grizzly also had many sharp burrs. We spent several hours working on it and failed to bring it up to acceptable level. The owner decided to send it back.
Now this is just one case. Maybe neither of these two machines were representative of the product, but I remain suspicious.
I would prefer to look at old iron that you can see and test before you buy.
Anybody got a big planer...YES
http://www.woodcentral.com/woodworking/forum/classifieds.pl/page/1/md/read/id/18683/sbj/machines-for-sale/
I extolled the virtues of this machine when it was first posted. I would drive 500 miles to fetch it if I needed a planer for my shop. There is nothing better to be found for a serious home, light commercial shop. An identical machine ran our hardwood planing business for 25 years. But maybe you missed my post at the time.
Kneale Brownson
Re: I'd jump on that one......
Kneale Brownson
if I didn't have an old 18" Delta three-phase 5hp with 3hp feed motor.
