THE WOODRAT IS BACK!
Deck screw recommendations?
Virgil Johnson
I need to install some 1" x 5.5" PT pine decking. I nailed the last stuff I put down 22+ years ago. (spiral galvies...screws come along way since them..) I tried some DeckMate screws but did not like the way the pine fuzzed up around the head. Threads did not seem really aggressive either. Fastenmaster make a screw that looks promising called a Trio but no local stores stock them. Any other ideas? Thanks
Re: Deck screw recommendations?
Lee Schierer in McKean, PA
I've used Deck Plus 2.5-in Countersinking-Head Stainless Steel Star-Drive Deck Screw from Lowes to hold deck boards in place. They can also be removed if the boards need to be replaced.
Lee
Kneale Brownson
Second the star drive screws
Kneale Brownson
Their self-countersinking heads seem to not split boards as readily as traditional deck screws. Their easy removal can also be helpful.
