About the misleading year per inch drying rule
This story begins fall of 2016 with a cherry tree that blew down in one of our woodlands. It was a 22" tree with a crotch 11' up from the base. Seemed worthy of turning into some nice lumber and crotch wood for veneer.
The first disappointment was the crotch. As can happen the tree had included bark in the crotch, as can be seen in the picture below, and the crotch split upon drying. The future would hold no useful crotch wood veneer. Also, we sawed into numerous bullets, nails and spikes about 6' up from the base. Quit sawing, leaving a 4" thick center plank, seen in the picture below. The good news was the color and grain of the wood was exceptional. The lumber was stacked to air dry in an open shed Sept 2016 with less than best air circulation.
Son-in-law that helped with this logging project asked to have a chest of drawers built from this lumber. Seemingly sufficient lumber was put into a loft spring of 2017. The loft gets hot in the summer and will take cherry to 5% moisture content by late summer. We pulled lumber out of the loft and rough cut pieces for project Christmas 2017.
It is amazing the problems lumber can have when you get right down to turning lumber into finished parts ready to fit. Through a series of problems I came up short 4- 19" long pieces for the top and bottom rails of the side frame of the chest of drawers. These pieces had to have rift grain. After a month of fretting and trying all alternatives I was forced to whack these pieces from the 4' thick plank from the center of the tree. This plank had remained outdoors but under roof for 17 months. The chest of drawers would remain at a standstill until these 4 pieces were dry enough to use.
Good news followed. This 4' thick plank measured only 16% moisture content after only 17 months of air drying outside under roof. So much for the year per inch air drying "rule".
Our new gas stove has a "Warm" setting that keeps the oven at 140 degrees, perfect for taking these resawed pieces to a target of less than 10%.
