Birds Eye Maple
Birds Eye Maple
Birds Eye Maple
Don Stephan
While I expect spiral cutter heads are a better choice, they are not in the budget for one piece for a customer. With the traditional 3 knife cutter head in my 8" PM jointer and I think 2 knife head in my 15" Jet planer, how likely are some of the eyes to pull out when surfacing birds eye maple?
Re: Birds Eye Maple
Re: Birds Eye Maple
Keith Newton
That depends on a number of things, sharpness being the most important since you won't have control of some of the others like sharpness angle and cutting angle.
Another thing that helps reduce the risk, is to wet the surface right before running it over or through the machines. Wet wood is only about half as hard as dry, so it makes it easier on the knives. However let me warn you to be sure to wax your jointer beds before you try to surface any wet wood. The wetness makes it try to stick so feeding it becomes jerky. That won't be an issue with the thickness planer.
Re: Birds Eye Maple
Re: Birds Eye Maple
I have never failed to successfully joint anything. If it picks out go Sloooooow. For thickness maybe you can find a Performax sander to borrow.
My experience with maple is that it is unpredictable. Some is a brittle texture and prone to grief. Some planes as well as anything.
Re: Birds Eye Maple
Re: Birds Eye Maple
Dick Coers
Another technique that can help if your machinery has the width, skew the wood at an angle as you feed it through.
Re: Birds Eye Maple
Re: Birds Eye Maple
David Yoho
I used a combination of the previous replies with good results before changing over to a Shelix head on my 8" jointer.
If I had to dress figured wood for an important project I would remove and sharpen the knives on my jointer head using my Tormek. Then I would joint the material using a very shallow setting and slow feet rate. Once ready for the planer (13" two-speed Delta lunchbox) I would dampen the surface with a wet sponge and feed at an angle when I could. Even if there were rough spots from the jointer, they were usually improved by the planer due to the higher speed of the cutter head.
