Corner desk
Gitche Gumee Kid
Need construction details on various methods of securing the desk tops at the 90 degree joint.
Corner desk
Gitche Gumee Kid
Re: Corner desk
A few more details would be useful. Do you want it to be knock down or permanent?
Google "Countertop bolts".
Festool has a solution for the 700 model Domino.
Then there are dowels and many more.
Re: Corner desk
Lee Schierer in McKean, PA
Where I used to work we had corner desks and there was a metal plate that was screwed to the bottom of both parts. The plate was about 4" wide and about 1/16" thick and was an inch or two shorter than the desk parts on each end.
Lee
Re: Corner desk
Yonak
Aprons and interior braces between the aprons could help.
Re: Corner desk
William Duffield
Does your concept of a "corner" desk mean one with a triangular top, a pentagonal top, an L-shaped top, or a rectangular top with a non-coplanar rectangular return? What materials and construction techniques are you planning to use for the top surface(s)?
Re: Corner desk
William Duffield
For example, this corner desk that I built probably is nothing like what you had in mind, but it does fit your description.
It's construction is board and batten, a perfectly acceptable choice for my desk, unless you don't understand differential wood movement and the details of the fastening method that are hidden in the photograph.
Re: Corner desk
Gitche Gumee Kid
Planing on a simple L-shaped co planer top using pine. I like your board and batten approach.
Much obliged to all,
GGK
Re: Corner desk
Don Stephan
Figure eights, wooden buttons in slots in the apron, pocket screws in elongated holes in the apron.
Re: Corner desk
William Duffield
Make sure you elongate the screw holes in the battens perpendicular to the grain direction of the top boards. The boards and the battens in the desk in my pictures are all flat sawn ash. The boards of the top are glued with regular TiteBond and spring joints.
Re: Corner desk
johannaj
This office room is about 11 feet wide. The desk top is three pieces. I joined them with countertop bolts.
