Ceiling air cleaner
Ceiling air cleaner
Ceiling air cleaner
Ron Pemberton
My JDS ceiling air cleaner bit the dust. It was about 10 years old. Guess it got tired. I'm in the market for a new one. What are your ideas of an efficient dependable one. Thanks.
Re: Ceiling air cleaner
I have the Jet version someone gave me used. It's working well. Other than that I can not help. I also have a homemade version made out of a furnace blower.
OTOH, it's a pretty simple device, basically a squirrel cage fan in a box with some controls. When my homemade version died, it was the motor. I was going to rebuild it around a different blower when I realized I could just swap out the motor, and I did. Might be easy enough to fix yours. If its the controls and yours croaked, you could wire around them and install a simple switch or put it on the circuit with the lights.
Kevin French
I built one on that idea. I went to HD and found a workable size Furnace filter, and built the box to the size of the filters. I doubled the furnace Filters back to back, then took an old screen window frame cut that down to the size of the filters and put a ShopVac bag in that frame using the cord like a screen. The dust goes thru the 2 filters, then the ShopVac bag with the cleaned air thru the squirrel cage blower. Works great.
Replacement motor
Hoa in Alameda
I would first check with JDS for availability/cost of a replacement motor.
