Full size Door idea
Full size Door idea
Full size Door idea
Tom Norton
I have a pair of exterior doors in my shop. They are the normal metal "raised panel" steel doors. I have been considering making a new set of doors using an engineered type approach. I have built exterior doors before using solid stock and the typical shaper cutter approach.
So here is my idea for an insulated 2.25" door. 3/4" frame work with stiles and rails. Interior area insulated board. 1/4" exterior ply glued to both sides via vac bag. Then 9/16" cedar T&G on both sides.
Thoughts???
Re: Full size Door idea
That will work, but kaes a thick and heavy door, Although, probably not much heavier than a steel door.
Why not a 1/2" frame with foam and Cedar on both sides?
How wet will this door get? Water soaking through may eventually damage the interior frame.
Tom Norton
Barry, in the past I have built exterior doors in 1.75" & 2.25". Easier to use the 3/4" stock plus I gain a bit more insulation.
It is an East exposure and it stay quite dry. Plan is to use cedar for the internal structure.
The idea is to have a "real' plank style door. Not sure I could find one for $50.
Tom Norton
Interesting that the previous post by someone has been deleted.
Elaborate?
If someone deletes their own post, it shows up in the message list as "Message deleted by poster." Only a moderator can remove all traces. I haven't touched anything, and I don't think Bill has either. Curious. What have I missed?
There was another post....
Don't remember who. Had a line it about Why build something you can buy for $50.
Keith Newton
Tom, It sounds like it should work to me, but you don't say now much of the middle layer is insulation, and how much is wood. I don't think I would bother with vacuum bagging the 1/4" ply onto the foam. It's internal strength, especially tension would be quite low. I think I would run some cross rails at whatever interval you intend to fasten the T&G faces on with, so there will be more than 1/4" for staples or whatever you shoot through the tongue side with. It would be a lot easier to just use some liquid nails and staples to build that internal core and still have plenty of structural integrity. Just be sure to plan ahead, and not have any fasteners where you will need to drill for hardware later.
If you are using KD for the T&G, I'd plan on using a V-car siding type face with a little space to expand, because it probably will grow. However most Western Cedar around here is delivered green and full of water, so if it isn't KD, then make it as tight as you want, because it will shrink.
I would probably use a dot of mastic behind each plank by where the fasteners hit, and solid around the edges. The heavy mastic really sticks well to W Cedar. I've torn out some door jambs and side lights to replace with some I had custom made, and I literally had to pry it off, breaking it into little pieces about the size of hammer handle. I don't know who install that door, and had never seen the jambs glued solid to the cripples before, but it sure impress me as being stronger than needed.
Good advice from Keith.
One thing to consider is the lock set. Will it work on a door that thick?
Tom Norton
There is hardware for this thickness door as I have used it in the past.
The vac bag idea is because a number of years ago I made some light weight crosses for our church. I use foam board as the core and vac bagged oak ply over it using Titebond 3. Also had oak edge banding. I kept a sample of the glue up sitting on my window sill thinking that on day this idea might have another use!
Re: There was another post....
Tom Norton
Yep. There one moment and gone the next.
Kneale Brownson
Kneale Brownson
I'd question the integrity of the ply in an exterior application.
Tom Norton
I have used exterior plywood when I have built some garage doors and they have held up very well. The key is the adhesive.
