Turning square table top into round
The universal advice was to use a plunge router, which I don't have. I considered the band saw but the top was too heavy to control even on my large saw table. I have split many feet of pencil line sawing dovetails. Sawing is sawing I thought, regardless of the sawing device.
I did a practice run on one corner and it went well after I installed a new sharp blade. I am finding that the hand tool skills that I develop can be used to guide power tools. So I proceeded to saw out the circle, all 9 feet of circumference. The main struggle was to get good lighting on the pencil line.
Next came smoothing. I have found that a #5 plane is effective for smoothing convex curves like bow front drawers. The table radius was tighter and hence more difficult to plane. The edge was refined with the file. It is easy to feel if the curve is fair and I had only one lump to contend with where I ended the sawing. The smoothing operation took only 15 min to complete.
Re: Turning square table top into round
Kneale Brownson
Bingo!
Kneale Brownson
When I read "sawing dovetails" before looking at the picture, I was wondering how you made round cuts with a dovetail saw.
Excellent! I was wondering if you did it. I was thinking you might need a kick off top dead center and just do it. There must be fifty ways to do this, just pick one you are comfortable with and do it. And you did. Looks great. I think this was a situation where the apprehension was worse than the job. Good job.
Brian Holcombe
Smart way to do it!
A plunge router can work, but one needs to be careful about going against the grain, which can tear out and move the router as well.
Clint Searl
Clint Searl
A router on a trammel assures a finished perfect circle edge that can be further refined with an interesting profile using the trammel and/or pilot bits.
