Minwax Wipe On Poly
Alan Young
I am in the finish process of my Dutch Pullout Table. I stained the entire piece with General Finishes Antique Walnut Stain.
I then started applying Minwax Wipe On Poly (Satin) to the Base section. I haven't applied any topcoat to the table top or extensions. I am really liking the look and feel so far of the WO Poly on the base. (No Pics to show) I have applied two coats so far to the base and plan on a third as per the directions:
Surface must be dry and free of old finishes in poor condition, wax, grease, polish, dirt or other foreign matter.
Sand to obtain a smooth, uniform surface. Remove all dust.
If desired, apply stain, such as Minwax® Wood Finish™ Stain, to unfinished interior wood surfaces. Follow directions for application instructions and dry times.
Shake Minwax® Wipe-On Poly container thoroughly before and during use to eliminate settling on the bottom of the can.
Apply a liberal amount of Wipe-On Poly to a clean, soft, lint-free cloth and rub it into the wood.
Let dry 2-3 hours. Then lightly sand entire surface with fine sandpaper (220 grit) to ensure an even finish and proper adhesion. Remove all dust.
Apply a second coat. If a third coat is desired, repeat step 6 before application.
After final coat, allow 24 hours before light use.
But I am wondering how many coats of this I should plan on applying to the top and the extension ie: the eating/working portions of the table. Or should I use a different version for the Top-Something that isn't as "thin"
