I must sheepishly admit that, even though this product has been on the market for quite a while, I've never used it. I understand that it is a family of cyanoacrolates of differing viscosities. I've always been apprehensive about using CA glue for joinery, partly because of its fast tack and partly because I don't know how long it will last before it oxidizes or something and loses its hold. But now, I'm wondering if one of these products might be okay for gluing up picture frames. And, scarier still, whether I could use it with biscuit-joined miters?
On a pen turning forum members occasionally complain that the CA finish on their pen has developed cracks, and I remember one person saying the CA finish developed cracks when left in his truck overnight in a very cold part of the country. That makes me wonder if the dried glue is especially brittle.
I have been using CA for a long time....ten years or more. I would have to go to the shop and look at the "old" stuff, it was whatever they had at WoodCraft. It was about two ounce bottles with little squirt top spouts and a matching slip on cover. They were a bear to keep open and free flowing. Now I have switched to Titebond. Their packaging is MUCH better. The cap screws onto the spout much tighter and has a double or triple seal that keep the spout open.
I know nothing of the Chemistry, but there has been much discussion here about it's lack of long term durability.
It comes in about three thicknesses. The "thin" is less viscous than water. Medium is somewhat thicker maybe the viscosity of 30wt motor oil. I have not tried the thickest stuff. I commonly sue it to stabilize punky wood and glue chips and splinters back into place. Some I used over ten years ago appears to be in good shape.
There is a learning curve. The accelerant comes in a spray can and is very useful. Be careful though, when the glue kicks off it generates heat. Not sure it will burn you badly enough to cause damage, but you won't like it. I tiny amount can be startling. I have not tried a larger amount and don't want to. Also, if you spray a puddle it can froth up creating solid white foam. So, when I put on a significant amount I wait as long as I can to spray it and sometimes not at all. You can mist it very lightly, wait as few seconds and mist it again. I'm talking the smallest possible droplets and the least amount.
As far as putting joints together, Dry fit it, coat one side with glue, spray the other side with accelerant and assemble. Using the medium glue you have a few seconds to slip the parts into position. I have also assembled more complex things with glue only and once everything was lined up and in position, spray the exterior of the joints with accelerant and then leave it alone, unstressed for a while. My assumption is the accelerant will kick off the glue near the surface and the deeper recesses will grab later.
Be careful, I have glued my fingers together and to pieces of wood. I heard someone glued a finger to an eyelid. I have heard acetone will release it, but haven't tried it. I just pealed my fingers off leaving a little hide behind. Aslo, there are other things that will kick it off, backing soda?, your breath?...
When I had surgery, they used medical grade CA and glued my hide back together. No stitches. That version doesn't get hot. I had a terrible red/purple splotch and thought it was a horrible bruise. Turned out it was the glue and eventually pealed off.
I've used it for many projects. My biggest complaint is that it can have a short shelf life. Some bottles seal better than others and last longer, but since I don't use it in quantity it never lasts. I had to throw out most of the glue in last set I bought (3 viscosities of glue, activator, and debonder.)
Mine refuses to set up in the bottles. I understand moisture is the culprit. The Mercury Adhesives guy told me that most CA glue bottles will let moisture through.
Decades ago I devised a method to keep the moisture out. This really works:
Glass is best or very thick polycarbonate. I use a different container now, a wider-mouth sealed container with clamped lid that is easier to access, but the principle is the same: the indicator desiccant beads keep absorb any moisture in the air inside. The beads change color from blue to pink when they need to be "recharged" by heating. Indicator desicccant is widely available in bulk: https://www.amazon.com/gp/product/B000OUXA2Q (The price has increased since I bought these but any type will work.)
I find it interesting that StickFast now recommends "my" desiccant storage technique:
"When storing CA for an extended time, place opened bottle in a moisture tight jar (plastic or glass) with TMI’s DRY PAK. DRY PAK’s color changes from blue to pink indicating that the desiccant is no longer absorbing moisture. To reuse the DRY PAK when this happens, place the PAK into a microwave oven for about two to three minutes to dry out the desiccant. The Pak will again turn blue."
Kept dry, the glue will last for years. Refrigerating can extend the shelf life of unopened bottles. Parson Adhesives said the shelf life of their unopened CA glues is 18 months when refrigerated, longer when frozen. (They also told me that all CA glue in the US comes from four manufacturers, rebranded for sale. I don't know which is which.) Other mfgrs such as StickFast do not not recommend freezing.
BTW, that from Mercury Adhesives appears to be the Cadillac of glues. Not only do they have the best cap and seal (a stainless steel pin to keep the tip clear) but they claim their bottles are made from plastic researched and tested for it's impermeability to H2O vapor. What's better is they have a lifetime "no questions asked" warranty and will replace any bottle that sets up, regardless of how old it is. https://www.amazon.com/gp/product/B000XIHSAO
The worst CA glue I've ever had was EZ-Bond. StickFast seems fine. Hotstuff and Mercury Adhesives are my favorites, Hotstuff mostly since we've been using successfully it for a lifetime with no regrets.
I use thin CA a lot for stabilizing punky spots for woodturning but it has to be pretty special wood to make it worth it. Sometimes I use thin CA to strengthen hairline invisible cracks in turnings. My favorite for this is Hotstuff.
The black flexible CA is great on occasion.
I mostly use very thin CA with these capillary tips so I can place just a tiny drop where needed: https://www.amazon.com/gp/product/B000H7H4NW I keep an uncapped bottle of thin Hotstuff with on the shelf above my lathe with one of these tips. It has been there for 2 years and the glue is still good although I do occasionally have to cut off and replace the capillary tip. I have no idea why it has lasted so long. After each use I tap the bottle on a hard surface to dislodge any glue in the tip then squeeze the bottle a few times and listen for air escaping to make sure the tip is cleared.
I rarely use accelerator due to some undesirable propoerties.
For extended open time, Parsons Adhesives carries Parfix 3408 thin CA that takes 40 seconds to cure. Useful where more working time is needed. Mark Sillay touts it for a one-step woodturning finish and it does work well on most woods. Expensive and hard to find.
One warning, I find that some exotics such as cocobolo work as natural accelerators. If gluing tubes in pen I've used medium CA and inserted the tube FAST and fully - no second chance to adjust things. The thin stuff set up too fast on the surface to use as a finish.
As for using CA for bonding, I use it a lot to strengthen tight connections but not where I expect it to fill any gaps or provide structural support. It should be fine for splines and biscuits but I wouldn't trust it on end grain without some other support. I think it would work well with splines or biscuits on tight frames joints - picture frames don't experience much stress.
Water and a host of other chemicals like the nitrogen containing chemicals in you hide initiate the cure, so your procedure for storing it with desiccant is an effective way to lengthen shelf life. However, water or water vapor, will destroy the cured adhesive over time. I too store it in a desiccator with drying agent. I put my shellac flakes in there too.
Traces of contamination from manufacturing eventually will initiate curing no matter how well it is stored. For this reason one can expect companies that take great care in making it will produce a product with longer shelf life.
