Elem School Woodwork Bench Design?
Don Stephan
Visited a teacher at a montessori elem school this morning who encourages students to make some very basic projects, like a small bench or a pole bean pyramid.
Presently they are working on something like a particle board lunchroom table with fold down metal legs. I suggested some of the benefits of a more rigid workbench and he is very interested. They would likely have to be made using 2x4's and perhaps a 3/4" birch or MDF top (minimal budget). Can anyone point me towards some simple bench designs?
When I first started messing with woodworking after college all I had for a workbench was a long chest of drawers. Somewhere I found an article describing novel ways to hold stuff on the benchtop without a vise, clamps, or hold down. Can anyone point me towards an article or chapter in a book that would describe things like that?
Re: Elem School Woodwork Bench Design?
Yonak
"Somewhere I found an article describing novel ways to hold stuff on the benchtop without a vise, clamps, or hold down"
Was it like a vacuum technique ?
Don Stephan
It was a pair of plywood strips held at angle to each other, each with a pair of dowels into the bench top. Third triangular loose piece with a hook at the end. Push the work against the hook, slide the pair between the two doweled pieces to wedge all tight so the work could be planed, card scraped, etc without moving around. Much harder to explain than it was to use.
William Duffield
You should investigate the Nicholson (English) bench. It is easy to construct from home center 2x materials, and knock-down version designs are available.
Bob Rozaieski at Logan Cabinet Shoppe has a blog and several videos explaining its functionality and construction. Start here:
https://logancabinetshoppe.wordpress.com/category/workbench/
https://www.youtube.com/channel/UCbHEdqSJEG0RIiJfeF5-LCA
Mike Siemsen also has plans and explanations at Mike Siemsen's School of Woodworking. Perhaps most immediately important, Mike has a video explaining and demonstrating work holding on this bench without vises. Of course, when time and funding are available, vises can easily be added.
https://www.youtube.com/watch?v=yvhn-PAfEW4
