Evapo-rust
Jerry Gibbs
Anybody tried this? Looks pretty good and water based.
Evapo-rust
Jerry Gibbs
Re: Evapo-rust
John C Lucas
Its fabulous. Ive used Naval Jelly,.reverse plating and evaporust to restore.tools. i like the evaporust the best.
Re: Evapo-rust
Chuck Bjorgen
I bought a gallon jug of Evaporust five or six years ago from a local Harbor Freight store. I’ve used it to de-rust several hand planes and found it to be an excellent product. One downside is that it can leave a dark patina on cast iron after use. This can be removed with fine sand paper. I generally use the 3M green pads along with a light solvent such as WD40. After use, pour the stuff back into the jug. It looks terrible after many uses but is still effective.
Re: Evapo-rust
Gary Smyth
Use it all the time. Soak for three to 24 hours. Will darken metal, but clears rust. Can use without gloves. I know the name sounds like a joke, but it works. About $20 gallon at Tractor Supply. Reusable as long as yellow color until it turns black color, then dump as it's safe, I put it into compost bin and let it filter through.
Re: Evapo-rust
Andy Lincoln,in Deaborn MI.
Works great.If you have an Advance Auto nearby its currently $18+tax if you buy on-line and pick up instore.
https://shop.advanceautoparts.com/p/evapo-rust-rust-remover-1-gallon-er012/10181905-P?searchTerm=evaporust
One Problem with it
Ray - Middletown, IN
After a fire several years ago I had to de-rust everything in the shop. Worked great on everything but calipers. The round spring broke on every pair of calipers I had after soaking in the product. Some new, some old, varied the soak time, nothing worked. Ray
Also on Amazon...
Mike Farinella
https://www.amazon.com/s/ref=nb_sb_ss_i_3_10?url=search-alias%3Daps&field-keywords=evapo-rust+rust+remover&sprefix=Evapo-rust%2Caps%2C505&crid=28KCKSANW8D62
Re: Evapo-rust
Tony - Memphis
I have used it for a couple of things and been quite pleased with the results.
Tony
