Old Brown Glue Question
Tom Norton
I started the process of gluing up my Shaker Chairs today. The Old Brown Glue arrived this morning!
I started with the front assembly of 2 chairs to get my feet wet as this glue is new to me.
My question is how do you,those who use this product, clean off the squeeze out? Both while it is still a bit wet and also when it is dry?
Thanks!
Re: Old Brown Glue Question
Jack Guzman from Maine
I keep a toothbrush in hot water with a dry rag nearby. I shake excess water off the brush and clean the joint as soon as it is assembled. Wipe clean with the rag. Redip the brush after each joint to get rid of glue that might get in it.---Jack
your should avoid squeze-out
Old Brown Glue is made liquid with chemistry that causes degradation of the protein over time and hence bond strength. Hence, it has a shelf life and should be tested periodically. If it begins to smell like ammonia be wary of its usefulness.
Titebond liquid hide is made liquid with chemistry that does not cause degradation of the protein and hence it has a much longer shelf life. I store mine in the fridge and it is good for at least 5 years and counting.
But to answer your question with another, how are you applying the glue that you get squeeze out when inserting a "dowel" into a hole, mortise in a tenon or whatever? I deal with the problem by avoiding squeeze-out altogether. But if there is an accident what Jack does is probably best. However, strive to never have to deal with squeeze-out.
Re: your should avoid squeze-out
Tom Norton
Squeeze out seems inevitable when glue needs to be applied to the tenon & the mortise. My first chair glue are maple and will be finished with milk paint so I will be seeing how it goes. I have 4 cherry chairs where I want to really minimize squeeze out as much as possible.
Jim Dillon
Tom, after using liquid hide glue (Titebond), I've never looked back (at least for interior stuff). Clean-up is so easy. A slightly damp paper towel or rag right after glue-up and clamping does the trick. Working-time is great also. Love the stuff!! Jim
