Lubricated/stearated sandpaper question
I have typically used 220 or 320 sandpaper with stearate (white stuff) on the sheets for sanding between coats of finish (Lacquer) to knock the nibs off. Lowe's did not have any and neither did Home Depot. The guy at Wood Craft looked at me like I landed from another planet.
What gives? Am I out of touch? What do you use?
Re: Lubricated/stearated sandpaper question
GolfSteve
Home Depot carries Norton 3x. Check if your local store carries it. Good stuff.
GolfSteve
Another place to look is a local paint store. Not your run of the mill place, but a place with more comprehensive finishing supplies. One local place I use carries Sia abrasives. I think I use Siaflex or maybe Sialac? It’s blue.
William Duffield
I don't know which of your sanders need the abrasives, but if you are looking for Festool paper for your Festool sanders, the Granat, Titan 2, Platin 2 and Vlies abrasives are stearated.
Siasoft foam backed paper *LINK*
Dick Coers
Siasoft foam backed is the perfect abrasive for between coats. Cuts beautifully and a dream to use. Ask Vince for a sample pack to try, but I buy 320 in the 27 yard roll. My roll is old enough, I don't know if it's film or paper backed. It's not the blue color he sells now, mine is pink.
http://vinceswoodnwonders.com/siasoft-paper-and-film-backed-abrasive/
dave nichols
Auto body supply store would have the sandpaper in stock in 9x11 sheets
