Lenox Diemaster bandsaw blade 1st impressions
Denny
I replaced my worn out Wood Slicer blade with a Lenox Diemaster 2 bi-metal blade. The saw is a Jet 16" that takes 123" blades.
My immediate impression is that the Diemaster doesn't cut quite as smooth as the Wood Slicer, but a few passes with a card scraper cleans things up. On resawing, the blade cut straight, no barreling or drift problems. I tensioned it the same as the Wood Slicer, no problems.
The specific blade I got was a 1/2" x .025 4 tpi hook tooth. The price ($40) wasn't that different from the Wood Slicer ($32). If you're looking for a 3 tpi blade, you have to step up to a thicker band.
Bottom line, if the Diemaster stays sharp for a reasonable time (as expected for a bi-metal blade), I'll probably never buy another Wood Slicer.
Denny
