Not totally OT-Navy and Air Force Colors
Alan Young
Alan Young
I am anticipating making another chess set. The scheme will be Navy/Air Force. What colors would be appropriate for such a scheme? I will probably be using steel for each set then have them powder coated. If Brass is appropriate I will use that. Thanks for all who have served.
-Alan
Re: Not totally OT-Navy and Air Force Colors
Can't answer for the USAF, but the Navy colors are blue and gold.
Lee Schierer in McKean, PA
USAF colors are silver and blue.
Silver
and Light Blue
:D
[Navy is Dark Blue and Brass]
Re: Silver
Dustmaker Mike
If you are making the pieces out of metal then use brass color for the Navy and Silver color for the AF.
Gary Smyth
U.S.Air Force colors
Colors
The Symbol is available for use in blue, black, grey, chrome-silver, chrome-blue and white versions. Each of the colors is specified below in standard Pantone CMYK and RGB options. Pantone is a widely used color matching system designed to ensure that color output is the intended color. If the exact Pantone color is unavailable, it is easy to reproduce the exact color combinations in most software applications by adjusting the percentages of different colors. CMYK represents the colors Cyan, Magenta, Yellow and Black. Mixing these four colors can produce nearly all colors. RGB represents Red, Green and Blue and mixing of these colors can also create most other colors. Below are the Pantone numbers and optional CMYK or RGB mixes.
Symbol Color Pantone Cyan Magenta Yellow Black Red Green Blue
Blue 287 100 69 01 11 0 48 143
Grey Cool Grey 7 0 0 0 50 166 166 168
Chrome Silver 877c 38 27 26 9 143 143 140
Chrome Blue N/A N/A N/A N/A N/A N/A N/A N/A
White N/A 0 0 0 0 255 255 255
Black N/A 0 0 0 100 0 0 0
U.S. Navy
Image result for Official U.S, Navy colors
Color Identification Code
Description
Pantone Matching System
Blue PMS 294
Gold PMS 1235
Red PMS 1805
Brown PMS 168
You wil need a current pantone color guide (old guides tend to fade colors) to view the colors as a computer screen is useless for accuracy.
Most auto stores can reproduce official colors, but may be pricey in small quantities. Hobby stores may stock air brush paints for modelers.
Look up Official colors for th U.S. ----------.
Plenty of information on the web.
There are different shades of blue for both services depending on vehicles, aircraft, ships. Look for the official colors and chip chart, but do not rely on computer screen. Air Force Blue is lighter (sky) than the Navy. Silver and Brass color will help separate the two opposing chess pieces.
Re:  -Navy colors
Philip Duffy
Just be careful that the Blue is a very dark Navy Blue, almost a black. Philip
Might be cool to use aluminum squares and wood squares dyed with blue. Then mill the pieces out of aluminum and brass. But I'll salute whatever you come up with. T
Alan Young
Thanks all-Very Helpful info...
Alan Young
Alan Young
I did a set with Aluminum and Brass-Looked great-The weight difference was a concern- If I do that scheme I'll have to mill out the pieces-Adding lead shot to the aluminum and losing weight on the brass-may even things out...Totally like the Blue Stained Wood/ Aluminum Squares for the board--
