Delta Drill Press Woe
Tom Norton
I have a model 17-900 that is in need of a new spindle. But alas it is an obsolete part. I have been searching and am not able to find one.
Any chance someone here might know where one is hiding???
Otherwise I am afraid the unit will be heading to the landfill.
Re: Delta Drill Press Woe
Dick Coers
What failed on the spindle that causes it to be scrap?
Tom Norton
Took the spindle to the local NAPA to have the bearing pressed off. Both of us were sure of the direction that the bearing was installed. Both of us were wrong. There was a very loud bang!
That'll do it!
John C Lucas
Can it be welded.and remachined.
Maybe try Grizzly *LINK*
Dick Coers
They list the internal taper on the parts lists, and bearings show the industry number, so maybe you will get lucky. I also found this note on one of the parts lists for the Delta part. I think I would start with this one. Does your machine have that taper adapter in it?
http://cdn1.grizzly.com/partslists/g7948_pl.pdf
Re: Maybe try Grizzly
Tom Norton
I will take a look tomorrow to see if that adapter is present.
