Anybody got a FULL Indicator a dust collector.
My dust collector is outside in a closet. Sometimes I fail to check the bin and over fill it. Anybody got a Full indicator?
I see Oneida makes one but it's $148 plus S&H. Anything cheaper? That works?
Not sure how I would mount that on my DC bag.
Re: Anybody got a FULL Indicator a dust collector.
Mark Nowicki
A bright yellow Post-It note with "Check Dust Collector" in bold black letters would be my choice.
But it is your $150.
Pete in Holland MI
My system has a metal trash can pre-filter set-up. I cut a 1" wide slot vertically for 3/4 of the height, and affixed a poly-carb (need to use poly carb, as acrylic will crack with the numerous screws needed) clear lense with some sealer and a couple dozen screws. Makes for a good sight glass. Past experience is that my can needs to be emptied at about the 50% full level, else more stuff gets carried in to the filter bags.
Pete
My system empties into a poly bag in a trash can. Enough of the bag shows above the can to tell if it is nearly full. The problem with that is, it's outside in a closet attached to the back of the shop. I have to walk around back and open the door on the shed to see if it's full. It's a terrible burden, I'm old, have tinnitus, wear glasses, short, and the college I went to was not Ivy League if you get my drift, how much can one man stand?
Mark Nowicki
61 years old, contact lenses, 5'9", Concordia University (Montreal).
I don't know what I got since I haven't seen a doctor in two years, but last time I did, she wanted a report on my arse hole and privates.
What does all that have got to do with the price of tea in China?
I'm trying to say I need help from some modern technology. I'm too old and lazy to go around back to check on it. At 68 I'm afraid of wandering around too much.
Mark Nowicki
I don't agree with the too old part.
Joseph Mulherin
Barry, I think Pete had the right idea. My suggestion is to cut a slot in your inside wall and mount his idea using wooden wedges to the wall. You should be able to see hot full the bag is this way. Make a drawing to see if it solves your problem before doing any work on such.
Hmmm....
I will have do a little measuring. Maybe I can cut a hole trough the wall and just reach through and touch it.
Go high tech for the entertainment value
Dick Coers
Why not go high tech? Install an inspection camera inside the flange of the dust collector and run it to a lap top in the shop. You would want to install it in some kind of dust proof sleeve, but could be very entertaining to see the dust swirl when you clean up. You know, like watching clothes dry at the laundromat!
ben d.
A couple links to some information that may be of use.
http://www.sawmillcreek.org/showthread.php?79451-Ever-wonder-what-happens-if-you-don-t-clean-your-cyclone&referrerid=5960
http://www.sawmillcreek.org/showthread.php?118175-Dust-collection-Full-Indicator-System
ben d.
For my cyclone I have a bin monitor that ClearVue sells.
There have been recent posts in other forums about home made systems. For example, search for An inexpensive dust bucket saw dust level sensor new cheaper parts .
Mike Jurnigan in Zuni VA
hey Barry,
thinking outside of the box. how about a scale mechanism that would indicate at a specific weight that corresponds to your full position.
Mike
Jesper, Denmark
Re: Manometer on the piping in your shop.
Jesper, Denmark
make a standard manometer from clear plastic tubing with some light oil in ti.One end connected to atmosphere, the other to your piping to the dust collector.
You will soon find out what the "normal" pressure differential is, and when the filter is full, the suction in your shop will decrease, which you can see on the manometer.
Cheap enough?
With my cyclone I found the bin is heavier when loaded with fine dust than with chips and shavings. Unless the use was consistent a weight threshold might need to be set to the lowest expected density.
Kneale Brownson
My KIDS are in their 60s.
Kneale Brownson
The walk will do you good!!
Mark
Despite the onerous burden, wouldn't you still have to walk around back, open the door, check the can and then take action if the $150 Full Indicator instructed as much?
Sounds like good exercise !
Is the top filter a bag or canister filter?
Dick Coers
With the canister filter, you get a real mess when you don't empty early. I put a Thein baffle in mine and clean it out when it gets just less than 3/4 full.
Re: Is the top filter a bag or canister filter?
It's a top Filter bag Delta unit. the bottom bag is a plastic bag I have sitting in a 30 gallon trash can. The can is about four or five inches "short" of where the bag attaches. I can easily check it for full but I have to remember to walk out there and and look. You are right, if you forget and let it over fill up into the filter bag, it's a real mess. Doesn't take long if you are doing stock prep and a lot of planing.
I was just thinking that if there were a reasonably priced indicator I could add it would be helpful.
Hank Knight
Barry,
My oldest friend is an electronics wiz. He designed a shutoff system for my ClearCue cyclone that uses a photoelectric cell similar to the one posted above from there ClearVue site. It works wonderfully well. When the bin fills to the top, the chips interrupt the photoelectric light beam and the cyclone shuts off. I have the circuit schematic around here somewhere. If you're interested, I'll find it and send it to you. As I recall it wasn't expensive to build.
Hank
Hire an intern to check it?
If my dog were as smart as Lassie...
...What's that Girl, the dust collector is full...
My dog is a chihuahua and I don't think he is tall enough to see into the bin.
Re: Hmmm....
Joseph Mulherin
Barry, what is the material of your inside wall? If it is 2x4 the it would be eazy to insert a sightglass, but block wall would present problems for you. You just need to be able to see the fluff bouncing around to know when to empty.
