Veneer saws
Veneer saws
Mike Stafford
Veneer saws
Mike Stafford
I occasionally use veneer for the bottom of a jewelry box or for the lid of a box.
I have a veneer saw that I have been using for a long time, probably more than 25 years, not constantly but as the need arises.
Of late it has become quite dull and will not cleanly cut the veneer either across the grain or with the grain.
My question is how do you sharpen a veneer saw? Or is it not worth the effort to try and sharpen the saw? Just buy another one?
Re: Veneer saws
tell us what a veneer saw is
Is this saw for resawing to make veneer or what?
Re: Veneer saws
Re: tell us what a veneer saw is *LINK*
John McGaw
As he wrote "will not cleanly cut the veneer either across the grain or with the grain." A veneer saw is what some might call an obsolete tool although die-hards still depend on them. I have a very basic French veneer saw that must be 30 years old -- it came from Constantine's (remember them?) and I've used it maybe two times and not a all in the 20 years since I left Alaska.
Mine looks something like this
Re: Veneer saws
The fact that it has two cutting sides suggests one side is cross cut and the other rip?
In any case one could approach sharpening as I do. Select a fine triangular file. Under some magnification orient the file to reproduce how ever the tooth was filed the first time. This approach works for me for 2-3 sharpenings and then I need to have someone that knows what they are doing refile and reset.
Re: Veneer saws
Mike Stafford
Re: Veneer saws
Mike Stafford
Thank you Dick!
I know I am getting old but I completely forgot that I used to sharpen that blade and flatten it just as described in the video link you provided.
It has been a while since I sharpened my saw and I needed that reminder of how to do it.
Thanks a lot.
Re: Veneer saws
Both sides are the same
Dick Coers
You get two working edges, but teeth are the same. As shown in the video link, the teeth are also beveled from the gullet to the point of the tooth. So it works a bit like a knife with teeth. You cut with the bevel on the waste side. You need a file and stones to completely sharpen the blade. No set to the teeth.
Re: Veneer saws
For left-handers . . .
Steve Elliott
There is a type of veneer saw that cuts in both directions and can be used equally well by both right- and left-handers. Mine was made in France by Arno. Instead of a handle that sticks off to the side at an angle it has a block of wood attached to the blade that can be gripped comfortably.
Re: Veneer saws
del schisler
that is what it is i have one for yrs
Re: Veneer saws
A veneer saw must be.....
Brian Roberts
in reality a "toothed knife".
When cutting veneers that are stacked....with the intention being to butt the cut edges together (as when wrapping veneer on a cylinder) it is important NOT to remove a kerf as would be done if the veneer saw teeth are square across the teeth.
If the teeth are honed to a knife edge they actually cut rather than saw out a kerf.
Removal of a kerf's width of veneer would result in a gap where the stacked veneers are butted.
Re: Veneer saws
Re: Veneer saws
Ralph Lipeles
Mike I have a veneer saw that I bought in Constantines in the 50's. I don't use it often but when I do use it, it does an excellent job. With a piece of scrap wood as a reference edge it cuts squarely to the veneer. I have sharpened it several times over the years. I remove the cutting blade, clamp it in a vise and sharpen with a small triangular file. You don't have to remove much metal. Try to take even strokes so that you will not alter the curved cutting edge. Lastly, drill a hole in a small piece of 1/2" to 3/4" dowel and slip the file tang in it. That will act as a handle and prevent the file tang from going through your hand if the file gets hung up and you are not paying 100 % attention.
Re: Veneer saws
Re: For left-handers . . .
William Duffield
I'm left handed, too, and find the typical veneer saw almost impossible to control, so I made a new handle for mine. The original right handed handle is on the right; my custom dogwood handle on the left.
Note that I didn't get the compound angle just right. It works, but it could be a bit more comfortable. I would recommend that you make a prototype, and before finish shaping, try it out, and start over if it is not comfortable.
I sharpen both rows of teeth the same. The side I'm using works on either the push or pull stroke. The second side is backup. I can remove and reverse the blade with a screwdriver if the first side gets dull.
Re: Veneer saws
Re: Veneer saws
John McGaw
...to all this I'd add that if anybody is lazy like me it is possible to buy a universal replacement blade that will fit pretty much every veneer saw you are likely to have for as little as $5 from Highland. Probably somebody on ebay will sell you something straight from China for half that but I didn't bother to search very widely.
Re: Veneer saws
Re: Veneer saws
Tony-Memphis
Yes, is worth sharpening! I sharpen mine often. Not very hard to do and there are several good explanations out there. Only takes a few minutes and makes a big difference. I use a little too much force and probably the wrong sawing surface (whatever I grab!), so mine dulls quickly. It took me a few tries to get it just right, but it was worth the effort. You might want to play around with different rake angles while you are at it.
Tony
Re: Veneer saws
Thanks for that link Dick
Howard in Toronto
Watching him sharpen his saw could explain a lot of my most recent results.....
Howard
