Rolling lumber rake question
I am trying to consolidate stuff and make room in my shop. I have a tiny shop and a space in the next room for storage. I have been trying to figure out how to make better use of the spaces. Stuff has crept in and taken over. It's very hard to reconfigure things once they have been in a spot for some time.
I am considering a roll around lumber rack. I have lumber outside in a shed and more still under tarps. Once I bring it in and dress it and do initial prep on it, it tends to stay in the adjacent space until I use it in the project. I have run out of wall space so I am thinking about a roll around rack. Any suggestions?
Horizontal or vertical? Most of my stock is short enough that I could store it vertically. I doubt it will roll far, just enough to jockey my way around it. To those of you with mobile bases on tools, do you move them around or do they just find a spot and stay there?
Re: Rolling lumber rake question
Gary Smyth
There is an advantage to a roll around rack in that is that it can be filled with what you need, have what's on it assimilated into a "normal" environment and have it ready as you need it. If a "A" frame type, you can pull from both sides. All of this is good if you have the room. The disadvantage is the it takes up space, You need space for it to turn, maneuver and have a path on both sides so that you can get what you want with the least hassle.
In your case don't do it. You state you are trying to consolidate. A new rack in the existing (crowded space) will make things worse not better. Your lumber is covered, stacked and stored already. You would be building something for no advantage in regard to existing space.
If you are as crowded as you indicate it would be better to assess what exists/need and start chucking stuff out before adding something big new. How many fluorescent bulbs did you tell us you have? Lifetime supply of sticks? From what you write you need more space, not space filler. Have you considered an addition? Either that or less purchasing. You are not alone. I'm a house/estate sale addict. Over time there is good stuff but no place to display it to advantage. You need space! Me too.
Just my opinion.
Don Stephan
Years ago I built with 2x4's a lumber rack perhaps 2 1/2' wide, 8' tall, and 10' long, with very strong commercial caster wheels. After it became pretty loaded with wood, I began to worry it might tip over while trying to move it, so it's been stationary for several years now. Still on casters, but I don't try to move it.
Gary, You are correct, I do need more space and I have considered it. I considered adding an additional garage bay. Talked to an Appraiser friend who is also a woodworker. He did not recommend it based on it not adding much value in my neighborhood. Went and talked to a lifelong friend with a huge shop (compared to mine.) He pointed out that his shop was jammed full and he added an addition that was about 50% and it was jammed full. He added an additional building bigger than the shop and the addition and it is jammed full. He said don't do it, you just get more junk and fill the space. The stuff expands to fill the space allotted. So I did not add on.
Now what I need to do is purge the stuff, use it up, and empty some space.
The reason I was asking about a lumber rack is that I bring lumber in from outside storage for a project to have it handy and to let it acclimate to the conditioned space. With limited wall space it is laying in the floor and I walk on it. I was thinking that if I had a rack I could consolidate it somewhat making it take up less floor space. If the rake would move, even a little, it might help in getting around it to get to what is on the walls.
There is a wall of bookshelves and there is a pile of "shorts" leaning up against them. If I could move those to the new rack, it would open up the shelves. There are dozens of turning blanks on the shelves. I could move the turning blanks to less desirable storage and move things I need easy access to onto there.
My lifetime supply of bulbs are already out in the shed and the sticks can follow. My son has stuff stored here that can be rearranged.
I have a shaper I don't use often, that is on wheels and could be moved to where the sticks were.
Don, I am thinking I would not really move the lumber rack much, but enough to get around it.
The other thing I need to do is to use up some stuff. But If I use it up, what would I have? I would have to get more.
Kneale Brownson
Discipline is the WORD
Kneale Brownson
Wish I had it.
AZ in Colorado Springs
I have four tools on wheels. 1) TS: this is on four swiveling casters. Great to spin it towards the work bench for outfeed support. (It used to be on a mobile base with two fixed and two swiveling wheels -- what a chore to turn 90°.)
2) 14" band saw. This has the other mobile base. I just swing it away from the wall for cutting long pieces of stock, so that base works well in that application. The swiveling wheels are on the end of the base towards the blade.
3) lunch box planer. This moves around quite a bit to get near the shop vac, and then if space is needed for infeed and outfeed for long pieces of stock. All wheels swivel.
4) chop saw. It's moveable base is an old BBQ grill with the firebox removed. I put some 3/4" plywood across the top and centered the miter saw on it. Then I added stock supports on either side of the saw out to the width of the grill. For supporting long stock, I use a work mate (I made a support that clamps into the workmate with cleats so it sits at a level even with the miter saw). There's a couple of 2x4s underneath the plywood to stiffen it. I
My shop is also small, most of a two car garage, so being able to move tools around helps a lot.
John McGaw
If my own experience is any guide, I'd say "don't do it!". My own shop is half of a standard-sized two-car garage which I walled off and which has a slight protrusion on one end, maybe 7'X6'. I thought that wheeled was the way to go and with the router table and CMS stand it worked out OK. But the sheetgoods and small-stock roll-arounds did nothing to help and both were eventually scrapped. Now the sheetgoods stand on-edge at one side of the garage, medium-small stock goes on the regular lumber rack, and small-small stock goes in a large storage tub. The tub finally did get its own wheels but it still takes up less space than its predecessor. Oh, and really small bits of exotics and special turning stock go into storage tubs too but those are in a general storage rack at the front of the other half of the garage.
Joseph Piotrowski
long ago i made a small lumber cart based of plans form either wood or shopnotes or something like that.. if your garage floor are in as rough shape as mine, you can't over do attaching the wheels. if i ever make another one, its going to be at least 1/4 lag bolts though 2x material ti secure the casters. wood screws are not a good idea.
this was my first lesson about taking magazine plans at face value. there not all designed and built by real user of the end product. they like to fill content.
I have almost all my equipment on mobile bases including 20" planer, 8" joiner, Unisaw, Drill press, Router table. I connect the mobile equipment to the dust collector with sections of flex tubing, it seems to work well for me.
I have an industrial shelving unit on rollers that I use to store cutoffs up to about 7' long. Sheet goods are stored against a wall.
My shop is 30' X 30' with and upstairs approximately 30' x 10' with knee walls. My long lumber (and some shorts) are stored upstairs. My stationary equipment is my 60 gal compressor, 3 HP Grizzly cyclone dust collector, Lathe, surface grinder, Jig saw and some bench equipment, (CMS, Morticer, grinders etc.). I have cabinets lining most of the walls holding my smaller tools and accessories.
I think most of us have issues with overcrowding our shops with odds and ends including wood and equipment we seldom use.
Don't think there is an easy answer to eliminate the problem except to bite the bullet and get rid of some items or moving them to an additional storage area!
