Low bench top sawhorses.
Virgil Johnson
A while back I saw a set of low sawhorses in a magazine that sometimes features examples of fine woodworking and methods of work that I find interesting.
Not knowing if I would find a set of low saw horses useful I decided to build a set from framing lumber leftover from a summer carpentry project. I intend to make set from a nicer wood if I actually like using them.
Currently they are relegated to holding stock off the bench top which is not a bad thing since I can slide tools under the pile freeing up space to work in front.
Re: Low bench top sawhorses.
Typical Japanese horses
Japanese shoji makers (think Toshio Odate) have been using exactly this type of sawhorse for centuries. The difference is that these craftsmen typically work on a floor mat, not a workbench. I've gotten a lot of use out of a set much like yours. I made the height exactly the same as the table of my chop saw, so they serve a dual purpose when needed.
Nice work, Virgil. Thanks for posting.
Re: Typical Japanese horses
Virgil Johnson
Thanks for the compliment and the miter saw idea. I'll have to check the height against the miter saw table. Like any other tool such as the simple 123 block pictured their use is limited only to the operators imagination.
Outriggers
Yeah, Virgil, if your chop saw is set up with its own outrigger tables, you wouldn't have the need for these portable ones, but they sure come in handy if you're working on a deck or the tailgate of a pickup truck, or with variable length workpieces.
Question
How have you used the 123 block in woodworking?
Re: Outriggers
Virgil Johnson
I have the Dewalt table with the extensions but there are times I do the back of the truck thing when working away from home or for just a few cuts on something that won't fit on the table saw.
Re: Question
Virgil Johnson
Good question Bill. I use the 123 blocks often since I have a dozen of them left over from the tool and die days. Nothing you could not do with a wood block but I don't accidentally toss these out. I use them for cutting off on the table saw to prevent binding when using the crosscut sled. Just add an inch to the dimension and use the Biesemeyer fence scale. Yesterday I needed to raise the coat stand legs shown in the pic 3 deg for layout. Place one end of the leg on the bench, took the 123 block and placed 19.125 inches from the end of the leg (under the leg) and now the leg is elevated 3 deg. Used them for spacing the router guide a set distance for routing the miter slot grooves on my table saw sled. Use them for setting at 4 corners of doors when gluing. Weights for gluing. They are a good standard for checking squares,calipers, setting the jointer fence,checking tape measures.
Re: Outriggers
William Duffield
The Festool Kapex chopsaw's deck height is the same as the height of their Sys1 and SYS-MFT Systainers. This is just a small example of their system approach to tool design and usage.
If you check out Festool's Youtube video on the SYS-MFT, it might give you some additional work holding ideas you can adapt to your trestles. https://www.youtube.com/watch?v=Y9Vec8Jybj8
Michael Wilkins
The magazine you are referring to was the Fine Woodworking annual Shops issue we just received. I saw the 2 saw horse types and decided to make the low ones. The author used them on his bench top; I have found a alternative use by sitting them on the floor to elevate a cabinet project to a higher level for easier access. Especially nice when the cabinet starts to get more parts attached and the weight goes up.
Jim Dillon
Virgil, long ago I made a similar saw horse pair - though not as nice as yours. I use them a LOT. Mostly for elevating stuff off the bench during glue-ups and for finishing. I think you will find them very useful. I'm somewhat embarrassed to post this pic when I see your efforts, but here goes. Jim
Ha!  That's what mine look like too!
Tony-Memphis
I built some that are ~36" wide when I was building a table top. Came in real handy for clamping. I've used them for lots of other projects since. Some of those nice small ones would be nice to have.
My bench was not level, so I leveled the shorties very carefully and that worked good as a reference for the tabletop. Of course, a glued up piece of wood ~36 x 60 is going to do just what it pleases anyway, but at least I got it off to a good start and was able to check my joints and such.
Tony
These are mine.30 years old  at least.
Gary Smyth
Clint Searl
Clint Searl
I kept a stack of wooden I-beam cutoffs laid on their sides to lift stuff off the bench or floor.
I recently had to assemble a sofa table. I don't have an assemble table or one of the very flat torsion boxes. I sat two 2 x 3's on the floor and leveled them east west and north south to each other and built it on top of them. Worked well. Your horses would have been better.
