A glitch in my door hardware design
Alan Young
I'm wrapping up this bookcase with the brass grill and at the last minute found a glitch in my hardware design.
The brass fasteners I made to hold the grill and glass in place interfere with the vertical supports on the case when I open the door.
So I need something that keeps the door from opening past 165 degrees or so and prevents these brass pieces from nicking the exterior case corners. I could simply fasten a brass chain but that will be seen hanging behind the grill when the door is closed and I don't want that...I think I need some sort of hinge that can be fixed to the inside of the door just below the glass panel and fixed at the other end to the inside of the cabinet. Any suggestions are appreciated.
