Made a two ply lampshade which was not bright enough. I'm going to use one layer of veneer bonded to a sheet of either acrylic or plexi(I am assuming that these are the correct choices.) Is there a non-industrial type adhesive that is appropriate for this and that I guess would need to dry clear? Would a slower drying cyano rolled on be appropriate? Appreciate any suggestions since this will be my first time going this route. Thanks for the help!
It's been a long time since I played around with this but here are some thoughts.
I'm not too hot on the idea of acrylic, unless you sand blasted one side to gain some tooth for the adhesive, then I'd choose an epoxy, or maybe a polyester resin.
Using a thin fiberglass fabric might give all the toughness you need while being clear as well.
What wood species have you chosen?
Light woods are usually more translucent than dark woods which absorb the light.
Woods which have a lot of figure like fiddleback or burls which have some of the grain running through the thickness rather than down the length allow more light to pass, and they all seem to allow more light to pass through better when wet than dry, so I'd try to find an adhesive that really soaks in and fills the fiber.
I have a friend that makes lamps and they are single, thick veneer in a light colored wood.
I would try spray-on contact cement for gluing anything to acrylic. However, many solvents dissolve acrylic plastic and that fact may be a problem in gluing to it. You might be able to spray a single layer on the wood and then stick it to acrylic sheet. Or, it may be that some contact adhesives don't involve a solvent that will dissolve acrylic.
It might be harder to find, but polyester sheet is insoluble in most solvents. It must be stable for it is used for film backing. Polycarbonate has another problem. Nothing you will be able to find dissolves it but many solvents "craze it and in doing so it looses strength.
The type of wood has a great deal to do with how it transmits light. I met Peter Bloch at one of the Woodturning symposiums and he discussed this. It may talk about the wood on his website.
Back in the 70s and early 80s, I made several lampshades and architectural panels using veneer bonded to plexiglas. In those days, I found two adhesives made expressly for bonding wood to plexi. One was a nasty-smelling three-part epoxy (two liquids and a powder) called PS-18, if I recall correctly. The other was called PS-30 and was a single part liquid. I got them from a plastic fabricator in our area. The PS-18 has held fine for decades.
Now, the caveat: as someone mentioned, the coefficient of thermal expansion of plexiglas is a lot greater than that of veneer, so when the plexi heats up, it will expand faster and open up cracks in the veneer, particularly if it is a brittle or ring-porous species. I had bad results with oak, but quite good ones with birdseye maple and mahogany. I imagine that pliable species like birch would also work nicely. (You should check out how cool birds-eye looks with light coming through it. The eyes look like little orange tapiocas.) Nowadays, with LED lights, the heat situation should be a lot more forgiving.
One other tip maybe worth mentioning is that, when you sand the laid-up veneer, do it over a light table so you can see in real time what the effect will be on the finished look of the shade. Otherwise, you could sand the veneer too much in spots and it will make the lighting uneven.
Yes, Dick, sorry for the search problem. Our native search function took a hit when our server team performed a critical security and software update a while back. I've been trying to find a Perl guru who can fix it, but I think we're just going to set up a resident Google site search utility here. It actually does a fine job.
To do a site-specific (WC specific, in this case) search for discussions of veneer lampshades for example, just follow this format:
