THE WOODRAT IS BACK!
OT :Intercom in the shop
Jack Guzman from Maine
My shop is downstairs from my residence. When my wife wants to tell me something she bangs on the floor until I hear it and then run up the stairs to find out what she wants. Poor system. I envision something like a loud buzzer(in case I have a loud power tool running) with an intercom panel to speak to each other through. Does anyone know of a system similar to this that might work for me? The older I get the less I hear and the harder it is to run up the stairs just to ask a question. ---Jack
Re: OT :Intercom in the shop
Terry Quiram
Instead of a buzzer a flashing light would be better.
This bell works well
ronster
SUNS CB-4-120 Gray 120V Alarm Bell 4 Inch 120 Volt AC
I can hear this over my equipment. I think the db level is perfect. My wife flips a hard-wired switch twice and 'voila' lunch is served. Thrice means come quick. Constant on = come running.
We tried the flashing light approach, but I didn't always see it. Tried a colored light; no better.
Bruce, a MN Galoot
When my wife wasn’t home (she worked evenings) and the kids were little I taught them to flash the ceiling lights to get my attention. It worked really well. My wife still does it.
Perhaps a light plus a sound would be good in case machines are running. My bin-full alarm for the cyclone uses an alarm module for a fire protection system - it has a bright strobe and an loud sound. All it would need for an alert would be connecting a power supply and a switch.
This is what mine looks like, mounted on the front of a plastic box housing all the DC control and sensing electronics.
An intercom which you can use to talk over is the easier part.
Yonak
I have a flashing light operated by a door bell button upstairs. Unfortunately, I always have my head down, eyes trained on my work, and I never see it. Now she calls me on the phone which I hear on my bluetooth headphones.
I have used the Panasonic cordless phone system for several years. It is not too expensive at less than $150, consists of the answering machine with handset and 4 remote handsets with chargers.
It has an Intercom built in and as my shop is detached it works quite well. I personally have never felt the need, but know there are several phone add-on devices that would allow loud alarms or flashing lights if desired. Actually I would rather not have them as I would worry I could become surprised / distracted while operating a power tool like the saw, joiner or router and either damage my work or myself!
I had no idea
Thanks for the good responses. Thanks to one I just went and looked and found that I have a built in intercom on my portable house phone set. Because I hardly ever read the instructions I never knew it was there. Just a tiny button with "int" on it. I tried it and it rings up any of the three phones that come with the set. I already have one down in the shop. Problem solved. Now to set up a loud buzzer so she can get my attention when it gets loud down there. When my lathe is running I can't hear anything else.---Jack
William Duffield
That's the same system we use. It works well here. The center of my shop is about 75 feet from the back door, and I don't have reception problems. The only issue I have with it is I sometimes have to search around the house to find a pile of hand sets and put them all back in their chargers. I don't understand why the dead battery issue never happens to the handset in the shop. :D
We also have backup systems. She sends me text messages on my cellphone which I carry in my pocket while I'm working. My MacBook usually accompanies me to the shop, so she can send me email, but I often have WiFi and cellular reception problems in the shop, so the backups are not so reliable.
Re: I had no idea
Pete in Holland MI
A loud sound could scare you at a critical point & cause an accident. A bright, well placed flashing light is a better safer option.
Don Stephan
All good and helpful replies, but few allow for selective hearing when one wants to hide . . .
Re: I had no idea
That might depend on the person. For me, a loud sound would not startle but a sudden visual thing off to the side might.
I suspect if you hook up a bell, buzzer, or other sound maker then have someone trigger it several times the tendency for it to surprise would be much less.
Here's a "startling" idea for an electronic's/arduino tinkerer: sense the machines running. If an intercom alert comes in when a machine is running save the event and sound the alert for when the machines are all off. A bit like an automatic blast gate circuit. Piece of cake. :)
X10?
Tony-Memphis
Something like X10 or even those Christmas light remote sets (probably on sale right now!) could work as well. No wiring required.
I have a Panasonic wireless phone that has the intercom feature and it rings when she uses it. I'm of the "loud noises startle me" crowd, so I would just plug a red bulb into a fixture that connects to a wireless controlled socket. I have a similar setup connected to my dust collector when it is on - there is a red light on the wall that lights up.
Funny, when I first moved in this shop, I had a rule - no clocks, no phone, no computer, etc. Yeah, they are all in there now. Oh well.
Oh, Lee Vally sells a nice door bell (a real live brass bell) that you might could rig with a string up top for your wife to pull! Or, you could even use a wireless doorbell for that matter. Hmmm, that might be the easy ticket there.
Tony
