Resaw clamping question...
I'm building a sofa table for a friend. Need a panel 11" wide and 5' long. Resawed a cherry board that has been air dried for ten years. The board was almost 6" wide and 3/4" thick. Book matched the two pieces last night and edge glued them. Five bar clamps, three up and two down. Snugged them up and got good squeeze out, double checked them for tightness and left them in the shop, in the clamps over night. This morning I started removing the clamps only to find they were no longer tight. Probably could have removed them without loosening them. The panel is fine. Ran it through the planer and the joint is good. I have bookmatched a lot of resawn panels and don't recall this happening before.
So what happened? Did it shrink because I resawed it and exposed the center?
. Go with the flow!! Jim
