Anybody know batteries?
Somehow I have four clock movements. I want to make something and Insert them into it either for sale or as gifts. I need the batteries. The slot appears to be shaped like a AAA, but smaller, about an inch long.
I have searched for them but can't get past AAA and the ones shaped like a quarter. Any suggestions?
Re: Anybody know batteries?
Jack Guzman from Maine
N
Sounds like a size "n" . Jewelry department of a department store by the watches or most hardware stores.---Jack
Thanks, that might work
I looked the clock over with a bright light and a magnifying glass and found FM-55 on it. If that's the battery, they cost about $20 each. That ain't happening. These stupid little clocks can't be worth over a couple of bucks.
I will check out size N. Thanks.
Stuart Johnson
Sounds like an A23 a small 12v 1 inch battery that looks like an AAA.
Re: Thanks, that might work *LINK*
John McGaw
If the FM-55 is the part number of the movement and it is a little round device then it uses the N size battery which is pretty common and cheap. I have a couple of HP calculators which use them.
Is the it?
Ralph Lipeles
Does it have a manufacturer's name or part number where you could hunt it down on line/eBay and see what the sellers say it needs?
Jerry Nicholson
Amazon.com shows gobs of N and A23 batteries. The size of these could be found in a google search.
Jerry
I bought size N, they work, Thanks
Now if I just had the correct drill bit. Something on the order ot 2 1/2". I have a 2 1/8" forstner and a 2 5/8" but none the right size. I also have hole saws, but none the right size. Looks like I will have to turn them on the lathe.
