Delta 22=560 Planer
Mike Farinella
My (somewhat old) surface planer won't crank up or down anymore. Anybody have any suggestions?
Delta 22=560 Planer
Mike Farinella
Re: Delta 22=560 Planer
William Duffield
Does the crank turn? Does the head lock handle turn?
jesse cloud
When my lunchbox planer had that problem, it needed a good cleaning. There's probably a chain mechanism to keep the movements up and down both post in synch. Mine is in the bottom of the machine, have to turn it upside down to access the plate that covers it. A good cleaning with an old toothbrush and some WD40, then some spray lube did the job.
Also make sure no crud has accumulated along the posts and that the springs are not broken.
Let us know how it comes out!
Mike Farinella
The lock still works, but the crank won't crank. ould be full of sawdust?
Mike Farinella
Thanks, I'm going to remove the dust cover today and look inside.
