Finally finished the A&C Side Board
Alan Young
Alan Young
A sideboard in the Arts and Craft tradition with some slight Greene and Greene influences.
Materials-Mahogany and Sapele.Finish- Oil and Shellac for the base,carcase,and doors. Oil and Polyurethane for the drawers and top.
Dimensions-35"H,19",D and 96" L
The right side opens with an upper drawer for Utensils
Three removable boxes sit above lower Silverware/Utensils compartments.
Three center drawers ride on full extension drawer slides.
Re: Finally finished the A&C Side Board
Absolutely beautiful! Congratulations on a fabulous job. 8' long? That's going to require a special place.
much admired
Hank Knight
Alan, that's a wonderful piece. Great job!
Nice!!
Virgil Johnson
Nice work.
Finely Finished
Alan, this is one of your better pieces.
Very nice!
Thanks for the pix.
Kneale Brownson
Re:" Finely" I See What You Did Here
Kneale Brownson
I agree too!!
Implausible for me to believe you made a piece of that size in your shop. You must have moved some tools around. :D Never the less, very nice work. I like the silverware inserts idea. Well done sir!
T.
All I got is WOW!!!
beautiful
Ray Mtn. Home Ar.
That is impressive .Really like that mahogany top.
Alan Young
Thanks every one...
Alan Young
This piece did push my shop's capacity-So much that I moved it to my Son's Basement shop for the final finishing as I have other project taking shape and ran out of room. for specifics: The top, the door and side panels and the drawer fronts. the accent strips on the base aprons and applied "feet"are all made from Sapele. The Legs, carcass framing and door stiles and rails are all Mahogany.
-Alan
Simply gorgeous Alan!!
Re: Beautiful work Allen!
Snazzy!
Haven't used that word in a while, but this piece suggested it to me. I'm always interested to see variations on classic themes, as you've done here with arcs and stylized cloud lifts. The result is, well, snazzy. Kudos, Alan.
Just curious, and maybe you've shown this in earlier posts, but is the base a separate construction from the carcase(s) or do those legs go all the way up through?
Thanks for an ambitious post and a fine accomplishment.
Alan Young
Design progression
Alan Young
Thanks Boss-These clients were great. They had a different Buffet in this location that was not as long and protruded out into the room further than they wanted so they requested
1. A piece that was long enough to occupy this wall- but narrow enough to allow passage between it and the dining table(Not shown in my photos)
2 the new piece must not block the heat register- and 3. They have a home with Craftsman elements to it so a design in the Arts and Crafts form seemed appropriate.
This was an early idea-
Then I suggested this idea-a mirrored structure on top with extra shelf space for smaller items- and a case with a rounded carcase-
They didn't want the extra mirrow/shelving and didn't like the rounded form of the case.. I suggested this form with a client a year ago and they didn't go for it either Hah!
I tried to push the design with some blatant G&G elements -ie ebony accents with breadboard ends-but they shied away from those elements too- in the end the liked the extra details on the base stretchers and feet and the cloud lift element on the doors.They did not rush their decisions but seem to have weeded out the frill.
Given their requirements and my shops logistics it seemed best to make the base separate from the casework.
I glued and screwed a piece of plywood to the top of the base-This added structural stability
Main case work built to the same perimeters as the base.
A 1.5" wide trim piece wraps around the base of the casework.
This allows the case to "cover" the upper plywood of the base and it gives the movers a lip to grab-
At this point I need to move this out of my shop as I have pieces for two other projects that I need to work on and there was no room- So I was able to move it to my son's basement shop-about a mile or so away where I did the finishing.
Re: Design progression
jesse cloud
Thanks for sharing the design progression. I am always curious about how designs came to be what they are.
It is a beauty.
And clearly you met the customer's specs - at first glance I thought the heat register was a decorative feature of the side bar. ;)
