OT- vehicle brake question
Tom Norton
I typically do the brake jobs on our vehicles and after 21,000 miles my wife's Ford Fusion may need some attention.
What I am noticing is when driving a slight turning off the steering wheel will cause a bit of rubbing sound to occur. It almost sounds like pad to rotor noise.
But would appreciate input.
Thanks!!
Re: OT- vehicle brake question
Mark Nowicki
Does the noise stop or changes when you apply the brake?
Any pulsing or vibrating in steering or brake pedal?
Dustmaker (Mike)
Brakes maybe not. There is a backing plate behind the brake caliper that might cause it but I doubt it. I would suggest jack up front end place on jack stands. Turn each wheel check for play. I bet more on a CV joint or tie rod then a brake part.
Right front CV joint is my bet. How many miles? 21000 should be covered under 5year/ 50,000 power train warranty.
21,000 is pretty early for brake issues
Dick Coers
Unless you live in Chicago!
I had to laugh the other day bicycle riding. I see just the steel backer of a disc brake pad laying on the street. Just how the hell does that end up on the street? A lot of stuff would have to go bad to duplicate that scenario! Unless it fell out of a garbage truck.
Re: 21,000 is pretty early for brake issues
Tom Norton
Yes,21k is not very long but I notice that the "mid-range" quality parts I get don't seem to last very long . I will check the dust cover/shield.
Thanks
