drawer slide
drawer slide
drawer slide
mike mcnerney
I am making a lateral 3 drawer filing cabinet out of mostly solid wood along with wood drawers, 34 inches wide My question is which slide to use and do I need 2 handles. The drawer fronts will be attached to the drawer box
AT first consideration I wanted to use a heavy duty blum under mount with soft close. I am also considering using a classic accuride. On my own steel lateral filing cabinet, that is what it looks like, and the drawer runs nicely. And it takes just one hand to pull it open easily enough.
Re: drawer slide
Re: drawer slide
Larry
I don't think you can beat the accuride full extension slides.
Re: drawer slide
Re: drawer slide
Gary Smyth
If you wonder how much a standard four-drawer filing cabinet weighs when full, the most precise answer may be a vague: "a lot." A regular, plain steel four-drawer filing cabinet, when empty, can weigh up to 150 pounds. Once it's full, it weighs significantly more. According to Conversion Technologies International, once it's filled with paper, upright four drawer filing cabinet may weigh approximately 440 pounds. However, some filing drawer slides can support up to 150 to 220 pounds per drawer, so it's conceivable for the same filing cabinet to weigh over 750 pounds -- 150 pounds empty weight plus four drawers weighing 150 pounds. Lateral files present similar weights but the tipping point is different. Something to plan for.
A 750 sheet ream of paper weighs in at 6lb 11oz. Add empty weight of the wood, folders, and hangars and it gets up there. Tipping toward the user can be dangerous..
The problem aside from selecting the drawer slides, say 220 lbs full extension, is also the cantilever of a full drawer pulled out. A lateral file is worse than a typical foot wide upright. At 36" wide at whatever depth with the top drawer fully extended and a crap load of paper some consideration of weight and center of gravity is warranted.
You will need full extension in order to pull out files. You might want to check the specs of similar sizes to yours from web sources. Cabinet attachment to the wall is something you might also wish to consider.
Re: drawer slide
two pulls
Dick Coers
Not a mechanical need for two pulls, but I want the two for the design aesthetic. 34" wide would look odd with just one pull in the center.
Perfect slide advice is already given.
Re: drawer slide
Re: drawer slide
mike mcnerney
Thanks for the thoughts. I knew the tipping point had to be considered so I am going to run some simulations & weigh a typical drawer & go with the accuride.
