New chair assembled
Cherry and white oak.
New chair assembled
Very Nice
why the mix of woods?
Because
You can steam bend white oak relatively easily.
The white oak spindles are easily shaped when green and dried fairly easily (I wrote the weight in pencil on the side - when it stopped losing weight...).
I have tried bending a cherry hoop. It didn't do very well. I wouldn't even attempt to do a continuous arm hoop in cherry.
I have a true anitque in 3 woods
Curtis Buchannan dated it late 1700's and made by a high end shop. The hoop and back spindles are hickory. Seat is white pine. Spindles are soft maple. I presume the choices were made because each wood was optimum for making a chair efficiently that would last. Mine is solid as a rock.
Agreed
but why not the whole chair in WH?
Don't see the advantage of the legs and rockers in cherry.
I've done mixed-wood pieces, but always to exploit the differences as part of the design language used.
I'm missing something on your chair.
Re: New chair assembled
Hank Knight
Very nice! Continuous arm Windsors are my favorite, and a continuous arm rocker -- WOW! It doesn't get much better.
Re: Agreed
The seat is cherry also.
John C Lucas
Ii havent made a.continuos arm.Windsor yet. Its on my to do list. Whe i took the class from.Curtiss many many years ago.i remember him saying that the 3 seperate.woods.were.common and thats why the chairs were usually painted. Soft wood for the seat for easy carving. Harder wood for the levs.because it took.good turning details and a good bendable wood for.the slats.and back.rails. sorry for all the periods im forced to use the phone right now and i have fat thumbs. I screwed up on my first chair and made the back spindles too thin. Curtiss wondered if it would hold up. Well i think that chair is 17 hears old or maybe a little older. We use it every day at the kitchen table and its still holding strong. I have 3 factory made Windsors at the same table and they have been reglued many times.
Ah Ha
Paint is the answer to the wood mix.
Re: Because
John McGaw
I've had good luck bending cherry but only very thin stuff. Made a large round cherry table in my early days (before I knew better) and bent the round apron from laminated thickish veneer and when I make Shaker boxes I don't think about using any other wood but, again, that is very thin stock. Right now I don't think I'd have the nerve to make a chair like yours no matter what the wood might be involved.
Joseph Mulherin
Beautiful work and chair, JL. Have you ever considered making one of Sam Maloof's rocking chairs?
You can obtain the plans from: Hal Taylor 41 Richards Ferry road Hartwood, VA 22406.
(Ph: 540-286-2586) At the time when I purchased them it cost me only $70.
Joseph Mulherin
Also, he has a website: RockingchairsUniversity.org
Bruce, a MN Galoot
Very nice job! Is that chair of your design or did you get the dimensions someplace? If so, where?
My design (sort of)
The basic plan for the chair started off as a regular continuous arm chair.
I had the seat pattern from a class I took years ago.
I adapted it for a rocker.
NiiiiccE
Stuart Hough
Looks outstanding, JL!
Re: VERY NiCE!
