I know you can clean up epoxy with denatured alcohol. IE, if you have some squeeze out, you can wipe it off with alcohol.
What does alcohol do to epoxy? Does it thin it or destroy it? If you get a little on the "good" part does it harm it or just evaporate? Could you thin epoxy with alcohol and not destroy the bond?
Epoxy is a thermo-setting system. If you use alcohol to thin it, the setting reaction can easily exceed the boiling point of the alcohol (Ethanol/Methanol) at about 180°. The alcohol will then boil out of the resin and you get foamed plastic with no strength and a real mess to deal with. I learned this the hard way. If you need to thin epoxy, use very small amounts of acetone.
The alcohol doesn't destroy the epoxy. You can thin epoxy with acetone and maybe alcohol. When the thinned epoxy cures and the solvent acetone or alcohol evaporates you are left porous epoxy.
Interesting responses. I clean up.epoxy all the time with alcohol. Never had a.problem. i have also thinned epoxy with alcohol without problems although i didnt use very much alcohol.
I have no idea whether Barry is talking about building a boat or a chair, or what woods, whether uniform texture, or open porous which will be stained.
What I'd like to hear is specifics. All of the brands I've used offer product manuals for how to use their products. He may be asking one thing, and you may be thinking another.
The thicker the epoxy layer, the more and higher heat it will generate. Spread the mix out thin so that the reaction heat is dissipated over a wider area you'll have no issues with heat. Pour it into a hole that's a inch thick or more and you may get deformation and even fracturing in the set plastic. Put a low VP/BP solvent in to thin a thick pour and get ready for the boil-off and foam even when using slow hardeners.
I don't know what I don't know. One of the really cool things about woodworking is that it is a "vast" hobby or endeavor and there is much to know about many facets. There are the mechanics and chemistry of wood. Then there is finish. And adhesives. And many many things to know about tools.
It seems I leap from one facet of woodworking to another. Building a deck one day and a chest of drawers the next.
I cut some dovetails with a Leigh jig and one set turned up a little looser than they should have been. They were on the back of a drawer, so I glued them with thickened epoxy. Used sanding dust from the drawers themselves as thickener. Cleaned up with alcohol. After I realized what I was doing, I taped off the inside with blue tape. It was about 99% effective, but I got the last percent with alcohol. It did a good job, but I was wondering if I had ruined what was in the joints.
Nobody had a clue what you were needing to know before your last post.
The thickening with dust from the sander bag is something I do. However, rather than wiping if off the outside, I would have used a putty knife or thin mixing stick to squeegee it in, eventually sheering if off, but leaving a little above the joints to sand down with a belt sander.
Epoxy doesn't load abrasives, and can be sanded before it gets totally hard.
For the inside, if the tape worked great, but if you wait until the epoxy is about as hard as leather, it's pretty easy to filet or cut it off with a blade.
Re: Now that is the kind of information I was want
What I was trying to figure out in this case was if smearing off with alcohol was better than waiting for the leather stage. I have waited with both epoxy and Titebond. Timing is important. Sometimes I don't have the luxury of timing. My woodworking can be a little disjointed. I make a glue up and have to leave before the leather stage occurs. Never mind the absence mindedness.
I did clean up the outside with a spreader. Actually a popsicle stick that was masquerading as a spatula. Somebody gave me about a thousand popsicle sticks and they are handy and disposable. And, you are fight, the exterior sanded nicely, just no way to sand the inside corners.
I was rather liberal with the alcohol. Trying not to leave any residue of the epoxy. So my query was whether alcohol leaking into the joint destroyed the epoxy.
What precipitated it was the recollection of what sugar will do to concrete. Way back when I worked in commercial construction. My boss accidentally ordered and entire truck load (8 Cubic Yards) of concrete too much. We had no place to put it and it was too far back to the plant to send it back. There was a grocery store nearby, I bought about a hundred pounds of sugar and we threw it into the truck and mixed it in. The concrete never set. Came out of the truck like a load of sand and gravel. Boss was happy, truck driver happy, concrete plant happy, I got a bonus....Actually he begrudgingly reimbursed me for the sugar. So, I was hoping alcohol was not sugar to epoxy.
Blue tape works pretty well for keeping epoxy from escaping out the back or bottom side of a joint, or for filling a crack. However, I strongly prefer packing tape. If you apply it carefully and evenly, then it can be peeled off after the epoxy kicks, without sticking and without leaving an adhesive residue, but with a smooth, finished surface.
