Resaw blade
Resaw blade
Resaw blade
James Runchey
I haven't done any re-sawing in a few years and am wondering what blade to order for my Delta 14 with a 12" riser. Seems to me I used a Woodslicer in the long ago, just can't remember. Age seems to enter in to the picture. I also seem to remember 105" as the length? Is there a better blade than the Woodslicer? Not interested on a carbide blade, at my age I'd never get my monies worth.
Re: Resaw blade
Re: Resaw blade
del schisler
here is the place i get my re-saw blade from they will stay sharp longer then the woodslicer blade call them i would get the 1/2" 3tpi i have the same saw as you
http://www.supercutbandsaw.com/
Re: Resaw blade
Re: Resaw blade
Howard Pollack
My 14" Delta bandsaw with riser block takes a 105" blade, just as you remember.
-Howard
Re: Resaw blade
Re: Resaw blade
Yonak
I can't recommend this company as their customer service is poor from my experiences. I have done business with many band saw blade suppliers. Industrial Blade has been the best and Supercut has been the worst. Strictly my opinion from my experiences .. YMMV
Re: Resaw blade
WRT Carbide blades
Brian Holcombe
I think it's a misconception that they last forever, they seem to last about 2-3 months of daily use for me, less currently with so much white oak being resawed. The most time I have gone is about 6 months, sawing walnut and softwoods, white oak kills them in a hurry (in my experience).
Re: Resaw blade
Re: Resaw blade
John Veerkamp
second super slicer
Re: Resaw blade
Re: Resaw blade
Yonak
James, from what I remember when I had a Delta 14", the blade length was 93-1/2" so, if you had a 6" riser, that would be 105-1/2" but, with 12" of rise, it seems to me it would be closer to 117-1/2"
Re: Resaw blade
Did Delta make a 12" riser block?
Gary Smyth
I have the 14", and added a 6" when purchased. Never knew about a 12" riser. Does not appear in the manual. Is it by a third party vendor? Have you a model number?
Re: Resaw blade
Carbide blades don't last forever
Bruce, a MN Galoot
But they can be resharpened.
Re: Resaw blade
Re: Did Delta make a 12" riser block?
John C Lucas
If he uses a 105" blade.its a 6" riser block
Re: Resaw blade
Generic term maybe since you get 12" resaw cap.
Re: Resaw blade
Is it possible to use two 6" blocks to make 12" ?
Re: Resaw blade
Re: Carbide blades don't last forever
Brian Holcombe
CT woodmasters can not be, so far as I'm aware.
Re: Resaw blade
Bruce, a MN Galoot
Lenox trimasters can be. Three times, I was told. Mine has been once. The blade cost $120, so I would demand something could be resharpened for that price.
Re: Resaw blade
Re: Is it possible to use two 6" blocks to make 12
Bruce, a MN Galoot
Maybe, but that would give you a depth of cut of 18" and I doubt if the rest of the machine is up to it. That sounds like a job for a woodmizer.
Re: Resaw blade
Brian Holcombe
I might switch, throwing away $150 blades is heartbreaking.
Re: Resaw blade
Quite sure the OP...
Brian Roberts
meant a riser that results in a 12" depth of cut.
Re: Resaw blade
I wish I still had the online picture of someone's modification of a Delta 14" saw with a homegrown riser that must have been 18" or more. It was a somewhat scary looking machine.
