200+ woodworking book reviews
Cabinet with marquetry door
Johanna Johanson
I finally finished a cabinet I started last fall in a class on veneering at Santa Fe Community College. I wanted to post photos of it here, but am having no luck uploading them from my computer. Even though I am a registered user, there is no place to select the files. I wonder what I'm not doing correctly.
Re: Cabinet with marquetry door
Photos
When you write a message, between the text box and format tools (H1, H2 etc) you should see ma "Browse" button. That will take you to your computer's hard drive which you can navigate to your photo directory. Select the image with a single click and press the "Open" button on your screen to upload your image. If the image is more that 150K in size, the software will tell you and you'll have to resize the image before uploading it.
Re: Photos
Johanna Johanson
I am no longer seeing the format tools! I'll try another browser, in case that's the problem - currently using Firefox.
Re: Photos
Johanna Johanson
Tried Chrome and MS Edge - still no icons for formatting. I'm logged in.
Re: Photos
Dick Coers
I'm guessing you have two accounts? Your first post shows your email behind your name, this last one does not.
johannaj
Re: Photos
johannaj
Aha! Thank you - I was not coming in under the correct account.
johannaj
johannaj
The cabinet frame is walnut veneer (bandsawn) on 1/2" Baltic birch. The door is 1/4" Baltic birch in a solid walnut frame.
I had read that article in Fine Woodworking on mitered bridle joints, so I tried it out on the door. It was a struggle - the top rail was re-done 3 times before I got it right. I'm not sure if I'll do it again - it's a really fiddly joint to make.
The first time I made the marquetry panel it buckled when it was glued to the substrate and the wrinkles could not be sanded out. So I remade the panel and used hide glue the second time. I also change the process from using a vacuum press to using weight pressure. I put the panel between two sheets of 3/4" MDF and put concrete blocks on top.
One thing I learned in the marquetry process was to use application tape on the veneer. It stayed on the front of the veneer until after glue-up. It was easy to remove and it was handy to be able to write on it.
Johanna
Placitas, New Mexico
jesse cloud
Great job Johanna!
Did you shade the lower leaves with hot sand?
johannaj
johannaj
Yes, Jesse, that is how they were shaded. I'm really enjoying marquetry; I've did a few little practice pieces before I tackled that door panel.
