Hot hide questions
Chairs are another matter. I don't make them-too complicated. Chairs not part of discussion below.
Apparently a few here use hot hide for furniture construction. My only encounter with it was watching marquetry being assembled, a situation where it seemed to be the only practical adhesive to use.
I have never considered using it for case piece construction because I think it has a very short working time and a learning curve that Titebond doesn't. I fear I would need its reversibility to take apart joints where I had not prepared and used the glue properly.
From other responses to the glue discussion below, working time, a combination of open time and closed joint working time is an important property of an assembly glue. I have never seen this property discussed for hot hide. My impression is that it has a very short time to assemble the joint and shorter still to adjust the joint after assembly.?. For those that use it, what is your experience with its working time.
In the example shown there are 38 dovetail joints involved in assembly. I prefer doing as many as possible at once so that the whole of the piece can accommodate itself to the stress of all the joints being made while the glue is still flexible . I wind up with assemblies more square this way. If hot hide has a short working time I don't know what strategy I would use to assemble this beast.
As it was I used liquid hide and did all the joints at once. First I did the horizontal dividers, then the top and bottom, and finally the vertical dividers.
What assembly strategy would be used on this piece with hot hide? How about a drawer. Is the glue still flexible in the first joint by the time the last joint is assembled?
