Back to the feed belt on the Performax.....
Like several others here I am struggling with the feed or drive belt on my 16/32 Performax. The original belt that came on it when I bought it used lasted for years and tracked fine. The second belt I bought at Wood Craft lasted five or more years and tracked fine. the third belt also from Wood craft would not track and I gave up on it and bought a film backed belt form Klingspor. It tracked well enough, but had to be adjusted about once and hour. Today it was running under a wide piece and I failed to notice it tracked away from the motor and shredded itself on the frame. The film backing is like a plastic bag, really tough until you nick it and then it tears like nothing. SO, I put the Cloth-backed belt from Woodcraft back on (because its Sunday).
Pardon my language but that bastard POS still won't track. I can tell which edge I had facing the motor before and it tracked away from the motor. So I reversed it. Now it tracks toward the motor. I have fiddles with the tracking until I gave up. I loosened the belt, slid it out and then made the belt tighter on the side away form the motor. I did it over and over. I was sanding some panels and would sand tow and move the belt. Sand two more and move the belt. Must have done it 20 times. I did it so many times I broke the adjustment bolt twice. I even tried doing it wrong. Nothing worked.
Tomorrow I may contact Jet. Am I the only one that thinks there should be a better way?
Any suggestions? Is it possible The machine is twisted? Since the belt moved toward the same edge of the belt even when turned around is it possible the belt is manufactured?
Re: Back to the feed belt on the Performax.....
Dick Coers
It's been my experience to track it a lot looser than you would think is right. You don't want it slipping of course, but try loosing it on both sides. With a little effort, I can slip my index finger between the belt and the table. So it's not really slack, but definitely not tight.
Thanks, thats about the only thing .....
I did not try.
The film backed belt I bought from Klingspor was so slick it had to be really tight or it would just slip.
I have to replace the tensioning bolts. I overworked them.
ben.d
First off I do not own one of the sanders nor do I know if the idler roll on the sander is flush to the top of the platen. With that said if the idler roll is just below a trick that I have used in the past to get belts so forth to track was to wrap a layer or two depending on how thick it is of the material that you stick down on concrete steps to keep you foot from slipping in the center of the idler roll causing it to be crowned in the center and helps correct the belt wandering issue. It may take one wrap or it may take two and may have to try different width of wrap, but probably a piece a couple inches wide would do it.
If nothing else works it won't cost much to try it, nothing to lose maybe it will help. If it works over time the wrap may have to be replaced.
ben.d
22/44 belt sources
ronster
Just to chip in for Performax users in general, my original 22/44 belt failed after several years. I got and am still using a thin replacement (Klingspor??), but it tears readily, developed holes quickly, and will soon destruct. In preparation I bought a replacement from 2sand.com. Looks real good. More like the original. Reasonably priced. Fortunately, I haven't had tracking issues YET.
Working on mine today
DizD
There is a brass bushing (oillite) on the feed roller. Possible this is worn to oval shape causing tracking issue?
Re: Working on mine today
Dick Coers
At the rpm of that feed belt roller, a bronze bearing should last 2 lifetimes!
I am about to go work on mine this morning. first, I am replacing the belt tensioning bolts/machine screws. I overworked them yesterday. I am going to try Dicks advice and run the belt slightly looser. Heres luck and skill to both of us.
Kenkrawford
Barry, email me at kkrawford at yahoo dot com. I may be able to help.
Let me know if you have any success
I probably won't be able to work on mine for another week or so. I've been reading all this advice but my attempts so far have been just like Barry's.
No luck....
I changed the bolts that tension the belt This morning. I had worn them out. Bought fresh ones at Fastenal and put them on. Fiddled with the tracking. Loosened it from the screaming tight I had been trying. Did not help.
The belt used to track away from the motor and got curled on the outer edge. I turned it around and now it tracks toward the motor. I can't find a way to stop it.
I am wondering if I cut the curled edge off would it help? OTOH since it moved in the same direction, toward the curled edge both before it was curled and after and no matter which way it faced, I suspect the belt. Could the belt be mismanufactured?
Re: No luck....
Hank Knight
"Could the belt be mismanufactured?"
Barry, that was my thought. That the belt tracks in the opposite direction when you reverse it tells me that the belt itself is not square and tracks to the tight side, even though the machine rollers may be properly adjusted.
A fresh set of eyes
Dick Coers
Where do you live Barry? Sounds like you need someone to visit. I wonder what a first class plane ticket will cost from Peoria, IL? LOL Either that or just sell the thing and have all your sanding done at a cabinet shop. Life is too short kind of deal. I'd suggest you start fresh with the adjustment. Forget any rules you are following to make the belt "climb" to one side or the other. Just use what will work. Take the belt off, and measure over the rollers to make them parallel. I might even put a framing square on the fixed roller to see if it is at 90 degrees to the bed. Now slide on the belt. Rotate one adjustment bolt a full turn to tighten the belt, then a full turn on the other side. Turn the feed motor on as soon as it will start to drive the belt. If the belt starts to move to the side when you tighten one bolt one turn, turn the other one 1 1/2 turn. Just sneak up on it. If you think that curl edge is hurting, trim a 1/2" off the belt.
You could check the belt length by cutting a story stick that snuggly fits inside the belt. Then slide it in the other side.
Re: A fresh set of eyes
Thanks Dick and everybody else. I have come to believe the belt I have is mismanufactured. The fact I can't get it to tract properly or track "the other way" convinces me. I am going to WoodCraft and get a new belt and if that one will track I am going to ask them to take this one back, even though it is two years old and has a curled edge. I curled the edge because it would not track. It has spent all but about two hours of the two years sitting on the shelf. Two hours of fiddling. I did not throw it away because my packrat gene would not allow it and did not take it back because it was curled on the edge. (was going to use it for sandpaper)
If neither blet tracks I will take both back and order a new one from JET. The Woodcraft belt is $40 and the jet one closer to $100.
I tried the film backed belt from Klingspor and it tracked better but still required side slipping it about every 30 minutes of run time. It finally crashed into the outer frame and shredded itself. It was very fragile and and had to be extremely tight to avoid slipping on the drive roller. The backing was very slick.
Now I just have to confirm the WoodCraft Store on the other side of Richmond actually has a belt and make the trip.
Minimal success...
Clifton C
Barry, please don’t think I’ve been holding out, it’s just that I’m so scared of jinxing my machine that i’ve been afraid to say anything. I went thru this years ago, 7? maybe 10 by now. I’ve gone thru three belts, the last one seems to be working better then the first two. I got ahold of a guy at Jet who admitted they had some belt problems. The last belt didn’t fix any tracking problem, just slowed down the march. One of the things I’ve done, in addition to most of what has already been mentioned, has to do with the bracket that holds the bronze bushing that supports the belt drive shaft. (the end of the drive shaft opposite the drive motor) I elongated the holes in the bracket (the holes used to bolt the bracket to the frame), so I could shift the drive shaft either closer to, or farther away from the table, I cannot remember which, it seems as if everything was working opposite of the way it should. I’ve looked at it just now, (broke out in a cold sweat, even after all these years) and can’t tell what direction I moved it and I’m not about to take it apart. Jet did send some ceramic blocks meant to force the belt into submission, but the belt is tracking now, so haven't used them. If/when it starts acting up again, I’m going to camber the idler/out feed roller…Or, tie a line to it and use it as a boat anchor…
Wonder what would happen.....
If I cut the belt into two eight inch wide belts and swapped the two halves so that one was pulling left and the other pulling right?
I called WoodCraft yesterday and they do not have a belt in stock. They are on sale for about $40 and they assure me they come from Jet so I had them order me one. We will see.
