Yes, made several...
John in NM
That is what I do with these tools.
I still use the two most successful designs. I never did try Brownell's tool because it did not look aggressive enough or random enough for the look and feel I wanted from the stippling. Looked far too slow for production work as well.
The first one I made was sharpened cut nails welded together then welded to a rod so it could be used like a hammer. It cut deeper than Brownell's design likely would and was undoubtedly faster and more convenient (no work holding jigging required because the tool can be used one handed). From there I moved on to the vibro engraver (they wear out quickly but give good results) and from there to the Foredom chisel tool.
I've stippled hundreds of grips with these tools. And the irony is that I like checkering a lot better, but for what I'm selling the market expects stippling instead (a copy of a German grip for a PSG1 rifle - originals are stippled so mine must be as well).
