I have a piece of Osage Orange 9" by 2 5/8" by 65"+/-. It has a natural gash right through it.
Having seen Mark's piece he rescued, I am inspired to rescue this one. Any suggestion on what to do with it?
I could make a long narrow table out of it.
I could resaw it and make two long narrow tables.
I could resaw it and book match the pieces and make a table about 18" wide. Probably 17 1/2" wide in honor of Home Depot. I've never seen a piece with two rivers.
First, what can you do with a piece of 10/4 osage? You didn't say where the gash is or what it looks like, so it's pretty hard to conjure up a decent notion here. Mark saw an opportunity relative to the split in his chunk of wood; you need to figure out whether the shape and orientation of the split in yours is worthy of being immortalized with a filler regimen.
Resawing makes sense if you want anything but baseball bats from this stuff. It does make nice turnings, and the thick stock would lend itself to plates, spindles, shallow dishes, etc.
As you say, if you resaw, you end up with two rivers. Maybe that's a design option. How could you compose those gaps in a bookmatch? Would the resulting look please you? What would you fill the spaces with that would best complement the color, texture and overall look of the boards?
On the functional side, do you need a table? 17 x 65 would make a nice sofa table, or a narrow coffee table. But it would also make a nice bookmatch for panels in a wall cabinet or something, if the grain is attractive.
Do you want to fill it? or would it still work with an open gap?
It's hard to know how to steer you on this. I tend to work around the cracks and voids but there is great creative potential in working them into the design. Ultimately, the creative input is going to be yours.
You are right. This really was a "how high is up" question. Really wanted to make it open, kind a hoping someone would go "OOOW! I had an idea for such a board". Without constraining them.
The river is not centered, but is about 3/4" wide in some places and probably 18" long. The ends are irregular. Wish I had a good way to post a picture. The grain is fantastic.
Resaw to get 2 lengths finished at 1-1/4 even if you only finish the top sides of the bookmatch.
Cut a 1/2" slot 1 to 1-1/2" deep down the center of each live face
Take a nicely figured piece of contrasting wood (walnut or maple) 12-13" wide by 1/2" thick (or ply with a veneered top face) by your finished length.
Glue up the pieces to make a 28" wide table top with the gap 3/8" below the top surface.
Inlay a piece of 1/4" glass to cover/fill the 10" gap in a rabbited section on each side of the gap or, if you have a vacuum pump able to pull the air out of a largish amount of mixed epoxy, fill the gap with an epoxy pour.
