Need Suggestions for a Display Cabinet
AZ in Colorado Springs
I’ve been asked to take on a project at my church -- turning an old wooden cabinet (approximately 15”wide inside) to a new purpose: holding three bottles of holy oils. The cabinet is to be lighted from the inside and no door is necessary. The cabinet is more than 6’ tall, so I have plenty of latitude on spacing the shelves on the inside. The cabinet is constructed from solid stock, maybe claro walnut or something similar; it’s a dark wood. The sides are eight vertical pieces beveled at 22.5 degrees, and the outside has been rounded. So, the inside consists of eight vertical planes. (The shelves will be circular, with the diameter sized to just come to center of the planks.) The opening is one plank wide, about 6” wide and 19” tall, but I will enlarge it.
The bottles are each about 7-1/2” tall and they’re not heavy (maybe two pounds), so I’m thinking three shelves spaced about 9-1/2” to 10” from the top of one shelf to the bottom of the next one up. Tempered glass, ¼” for the shelves?
I’m also looking for suggestions for the lighting. A corded solution would be appropriate. LEDs located below the bottom shelf? Of something above? Or both? How far below the bottom glass shelf, or above the top of the uppermost bottle, should the lights be positioned?
I realize that I’ll have to do some mock-ups to see what works best, but I’m looking for some ideas to start from.
Thanks
