River Fiddle
River Fiddle
River Fiddle
So the river top is done.
Finish is 1 coat of dewaxed Super Blond and three coats of General Enduro Clear Gloss.
The whole slab is showing fiddle-back figure:
Lessons learned:
1. Too much dye defeats the reason to use color.
2. Cured epoxy is not as hard as hard maple. Sanding with small sanders will leave the epoxy slightly below the wood's surface.
Self Critique:
River should have been wider, by a factor of 100-200%. While the filled crack is okay, it would have been more effective as a design element with more separation of the "shores."
Color in the bug-track filler renders the top too "busy" and detracts from both the river and the natural figure in the wood. While a bit of the fiddleback was showing in the rough surface, it bloomed when the finish hit it. Next time let the wood speak for itself.
Re: River Fiddle
Re: River Fiddle
Looks great. I want to do one. And I agree with your critique.
Re: River Fiddle
Lesson #3
When sawing fresh maple, hit it with TimBor as it comes off the mill to keep the damn bugs out of it!
Re: River Fiddle
Re: Lesson #3
I've been rolling that around in my head for years. It's a considerable amount of work and some expense. the main thing that has stymied me is the idea that when you mill the lumber you will be exposed to the chemical. Timebor would certainly be less objectionable than some of the others. Lyndane, etc.
Re: River Fiddle
TimBor
is not toxic to humans. It operates by blocking the bugs' digestive system when they ingest it; they starve to death. It's so effective because they cannot "eliminate" it and, since it's not a poison, they can't adapt to it either.
As explained to me, you and I can eat the stuff (TimBor NOT Boracare) and it just moves on through.
Re: River Fiddle
Most commercial lumber is treated
Shown is the dip tank at a large hardwood lumber manufacturer. All their lumber, and likely everyone else's is dipped to kill mold and bugs.
Re: River Fiddle
Nice hat
Re: River Fiddle
Wowee
Amazing piece, Mark, whether it's a river or a crick [sic]. Hard to believe I milled that tree with a chainsaw in 1978. Sorry about the bugs. I guess the message is that if you aren't having the wood kiln dried, you need to treat it before you stack it to air dry.
Great figure, great finish, nifty concept. All good.
