Knock Down Hardware for a Dining Table
Alan Young
I've been working on a Trestle Table in the Dutch Pull out fashion:
I want the bridge section and its associated stretchers to be removable so I made some knock down hardware for it.
These brass pieces are designed to be inserted in the end of the bridge piece that connects the ends.
Threaded insert goes into the end
It''s alignment hole lines up with the bridge hole
A 1/4-20 brass screw and turned bushing go through one side
and tighten to a turned tapped bushing on the other side
The bridge can then be joined to each end piece with a 3/8 inch bolt
There are then two more boards that connect the the tops at each end. This is the hardware used for this connection
the long rails are mortised out to accept two 3/8 bolts with washers and nuts
The outside of the end piece with the heads of the 3/8 bolts
Everything connected
-Alan
