Have a question? Ask Woody!
MicroJig Grr Ripper Questions???
Anybody have and use the Grr Gripper? Do you like it? Use It? Would you buy it again? What do you not like?
I bought part of one at a tool auction and am wondering if it's worth chasing down the missing parts. The auction house I got it at is notorious for scrambling things up. I saw other parts of it scattered around, mixed in other batches, but would have had to buy hundreds of dollars worth of stuff I did not want to get all the parts.
Re: MicroJig Grr Ripper Questions???
I use it, sometimes in pairs (I bought two) and really like it. I think it's more secure than a push stick and more appropriate that other hold-down methods foe certain cuts.
As for the auctions, if this happens again consider watching who gets the lots with the missing pieces and approaching them afterwards. They might give away or sell the pieces.
I once had the winning bid of about $50 on a huge box of mixed computer cables and before I got it to the truck I sold several hundred dollars of specialized PDP-11 cables to people who wanted just one cable and didn't want to bid on the whole lot. I had no use for those so I took whatever they offered. Everyone was happy.
BTW, that particular auction was fun. Shelf after shelf of computer components went for $100 or less until one which sold for (IIRC) over $20,000! (Full of high-end motherboards) I've never seen an auctioneer speechless - it really threw off his polished spiel for the next few shelves!
I have a couple and several spare parts. I would not think of working in the shop without them. I rely on them for use on my Unisaw, Joiner, and Router table. I have misadjusted them occasionally and made some unwanted slots. I immediately ordered spare parts.
I also use their microjig splitter on my throat plates. I have never seen or used any device that makes a table saw or other equipment safer than the Grr Ripper. With proper use they almost eliminate the risk of kickback (I have stalled out the 3HP motor on my Unisaw) by holding a board that had pinched the blade, using the Ripper.
I have no connection with the products except being a very satisfied user.
jesse cloud
I have a pair. Don't use them most of the time, but when I am cutting small strips, they are great.
There are a lot of parts you may not actually need. For instance, the splitter is good, but not really essential if you are using a pair of the grippers. Before you order, why don't you ask on the board if folks think those parts are needed and if
anyone has some spares they would like to get rid of.
A solution to an almost non-problem
Dick Coers
I bought a Grrrr ipper, and have never used it. I find it so tedious to have to set up something to shove two boards through the saw. I just cut up scrap plywood into push sticks, and cut through them. Then either recut or throw in the garbage when they get too cut up.
Tedious???
Denny
Dick, I'm not sure how you're setting them up, but I find it takes me less than 5 seconds to adjust the position of the hold-downs (which is generally all that's needed). I use them a lot, and consider them one of the smartest purchases in the shop.
Denny
Re: Tedious???
>>> ...I find it takes me less than 5 seconds to adjust the position of the hold-downs ...
Same here. I thought it was quick and painless. What I like about it more than a push stick it pushes the wood down securely while pushing it forward with a secure and safe place for the hand. With two you can pick up the first and put it behind the second repeatedly for a longer cut.
After I bought these and read the manual/watched the videos I was surprised at how versatile it is for special cuts.
Some videos: http://www.microjig.com/videos/grr-ripper-videos/
Re: Tedious???
Joseph Mulherin
The videos will not work on my computer...comes up blank and has a red X to disconnect.
Re: Tedious??? *LINK*
Denny
try this link...
On youtube
Re: Tedious???
Joseph Mulherin
Thank you, Denny, I fully appreciate having someone set me on the right site to view the videos.
I will probably buy two of them for when I start working my wood for the Maloof rocking chairs I plan on doing for my family members so they have something to remember me by.
