I am in need of one or more roller stands. I have a four roller stand that I use for the out feed side of my table saw or my planer. It would be nice to have another one for the in feed side.
I see the HDX roller stands at Home Depot. They don't look too bad - and the price is right. Thoughts?
I can't see how hese wouldn't work fine, JL. I have an old-style Ridgid stand that I use behind my bandsaw that works great. It might have been even less expensive than these. The nice feature of the cheap stand is that the top tilts by gravity toward the work, and then tilts level when the work hits it, so it can't get hung up.
I prefer outfeed tables to roller stands for tablesaws, FWIW.
JL, I have the same stand Ellis speaks of. The top can be locked flat, or left to tilt as he describes. The hardest thing you have to do is remember...if it is to tilt, have it flop toward the stock.
I have roller "stands" I use in my shop. I made mine out of an old tread mill's rollers. I made three that have about six rollers each in them.One is to the right of my RAS. One is the out feed of my Performax drum sander and the third is on a stand as the outfeed for the TS. That one can lift off and become the infeed for the Performax. On the TS I keep it tilted down very slightly toward the saw. The pieces enter and then rise very slightly.
If I had known you could get one for $25 I might not have made mine, but I like mine a lot and get a lot of use out of them. Not sure about the edge guard on the one at HD, but you don't have to use it. I twist mine abut 2 degrees toward the fence to help keep the stock against the fence.
I have thought about a outfeed table for the saw and to the right of the RAS, but it would be another flat surface covered with stuff and in the way in my tiny shop.
For that kind of money, I might get one of my own.
It was my understanding or misunderstanding the single roller like the one shown can be a problem if it gets off kilter or twisted from the table saw. The roller will try to pull the piece at an angle depending on which way it is out of square to the saw.
I have some of these stands and Stuart is correct that if the roller is not positioned absolutely perfectly the work piece can get pulled off to one side. Otherwise they work as designed.
For a few bucks more, I really like the platform style over the roller type. The larger surface of the platform gives a lot more utility. The rollerstands have a hard plastic feet that slide around too easily. The roller stands are okay, but I like the others are better IMO.
