A River Runs Through It
[no, not the movie]
Little while ago Barry asked about "river tops" for tables etm. So, since I had one planned, I thought to do this write-up in case anyone else is curious.
Last year I bought a large (8' x 30") 10/4 slab of maple from Ellis in the Great Reduction Sale. The piece had been cut from close to the pith and had a massive check almost dead center that ran 4'+ in from one end. My kind of wood, and just what I needed to make a slab top for my liquor cabinet.
I had originally planned to just fill the crack but when I cut off the 3' I needed the two halves fell apart. Perfect opportunity to do a river top.
As both halves were twisted, the first job was getting them flat and thicknessed. That was done with a router planing rig. Then they went through the P-Max to get them dead even. Next, since this was part of my PPB lot and was really chewed, I sand blasted the surfaces to get all the frass out of the bug holes and channels.
With the wood prepped I started the joinery by cutting 5 deep Domino slots in each face of the crack. Tenons were glued into one side and the pieces were pushed together to set the alignment while the glue dried.
Next the tenons were painted with blue TransTint die and the other ends of the tenons were glued and inserted into the opposing slots.
The two halves were then drawn together using pipe clamps. When the glue had set I could begin refining the edges of my river. This was done with my old Foredom CC flex and the assortment of burrs and cutters I've acquired over the years.
This is where the carving come in as I make the opposing shores of my river based on the topography of the wood grain.
Now for the "water"
The slab is flipped and 5" on either side of the crack and the ends are painted with AnchorSeal wax emulsion. This will act as both a resist and part of a seal. When the first coat is dry a second application is made. While still wet a piece of kitchen plastic wrap about 6 inches longer on each end is applied, smoothed out, and tapped in place. This will form the seal on the bottom surface. To put a bit of pressure on the plastic. It's followed with a long piece of paper toweling that gets taped in place.
The slab is then flipped again and the extra plastic and towel are folded up on the top to make way for two pieces of 1x3 that will act as end-dams with the plastic and paper lapped over the end pieces and clamped in place.
I used blue TransTint dye to color the 2 cups of epoxy needed to fill the crack for its entire length. I used a slow-set hardener to allow any air bubbles plenty of time to come to the top and slowly poured the crack full.
Next morning things are unclamped and the backing sheets pulled. The back seal is never perfect but the wax makes removal of the excess easy with a card scraper.
The slab is now flipped and the excess resin is taken down with a belt sander.
Finishing will proceed as normal and we will have a cabinet top with lots of interest and a deep blue river.
Well, maybe a creek depending on what scale you're viewing from
Re: A River Runs Through It
Wow, nice job, Mark. Let's see that baby again when it's finished. Hard to believe we cut and milled that tree in 1978.
Very nice. Nice non-traditional thought.
Finishing
Have some sanding to do then another shot with the blaster. From there I'll apply a sealer coat of dewaxed shellac. Then All the bug tracks will be filled with brown-tinted epoxy thickened with micro-balloons. Re-sand, re-seal, then top with Enduro gloss.
Looks like there's a lot of fiddle-back in this section. If I've managed to keep the original cross-grain alignment, it should be awesome.
I'll post when done.
Gary Smyth
Be sure to include close up images of the transitions of wood to epoxy.
Don't understand
what pic you're asking for. Transition? There's no transition per se. The epoxy is filled to and bonds with the surface of the cracks. I suppose you could examine that wood/resin joint but I don't have photomicroscopy equipment to make such an image.
Thanks for the write up, I am encouraged to give it a try.
My mind is running like a hamster on one of those wheels. (That's a good thing, the rest of me ain't up to running any where.)
What medium did you use to blast the frass? Seems like you would want to remove the frass but not even stipple the wood.
I like the Dominoes. Mine is arriving later today and this is another thing it might be good for.
Why fill the trails? Are you going for contrast? Just want a smooth surface?
I would like to see a top that is several years old. I fear the wood will squirm away form the epoxy.
And thanks for the idea of "infilling" a crack to create a river. I had always thought of using two live edges, but this has a lot of possibilities.
Please post followup pics, and thanks again.
And one more question...
The Anchorseal???
I usually try to apply finish to the back side of table tops for "balance" and to help slow moisture migration in and out. Do you think the Anchorseal will have any effect on finishing that side?
Questions
1. Medium - No.2 Blast sharp sand. Doesn't matter about the raw wood surface as all will be sanded to 180 or better during finishing. The blast removes the frass and also provides a good surface for the epoxy to bond.
2. Holes & Trails. Both. The tracks will be filled with brown-tinted epoxy and then sanded flat before final finishing. I just finished applying my shellac sealer which will allow me to mix less epoxy in the fill phase this afternoon.
3. Older top: Been 5 years and tight as ever. No squirming.
4. AnchorSeal: The wet emulsion plus the plastic sheet forms the seal and prevents the resin from sticking to the underside. The wax is scraped, washed, and then sanded off. AnchorSeal is a waterbased wax emulsion. When it dries, the emulsifier remains. You can just rinse it all off with a hose, a power washer, or a wet rag and some elbow grease. The scraper gets most of it to start as in the photo.
Thanks
Re:  Don't understand
Gary Smyth
Nothing so technical. You stated "This is where the carving come in as I make the opposing shores of my river based on the topography of the wood grain". .
When finished I'd like to see a detail (close up photo) of the visual transition line from epoxy to wood. This only to show the "banks" of the river following the topography grain of the wood. No judgement just a detail. Is the epoxy translucent? Can it be lit from underneath or is it a solid blue? No criticism either way, only how you made it work for you.
Ah, Gotcha
The "sloped" walls of the wood were paired back so that the resin wouldn't get too thin at the edges. The first 1/4" of depth is pretty much at 90° to the top surface. I thought about making a few "beaches" with carved projecting shelves, but in a piece this small I don't think they would have been visually effective. I also thought about doing a half pour and then laying in some crinkled aluminum foil as a reflective surface. In the end that went the way of the beaches.
The epoxy is transparent however I put too much dye in the mix. I gave the resin a "squirt" of the concentrate when 5-6 drops would have been sufficient. This was my first time using dye concentrate in such a large batch of epoxy. Next time I'll know better.
