THE WOODRAT IS BACK!
Whoa! Vertigo??
Whoa! Vertigo??
Whoa!  Vertigo??
I mentioned in a post below that I dragged about 6 cherry boards into my shop to start stock prep. I set them on the wing of my TS. Tiny shop blues.
Later, I was sawing something else and for just a second I thought the TS moved. It appeared to rise. Then it did rise for sure and the scrap pile beside it shifted slightly. I held it down with my left hand and turned it off with my right. Then figured out the giant pile of lumber on the wing was too much. I was home alone. I'm standing there holding the TS down. I found enough heavy things I could reach and piled them on the other side and then moved the lumber to the floor.
The lesson in this is Lumber won't fall off the floor.
Re: Whoa! Vertigo??
Kneale Brownson
Coulda been a lot worse
Kneale Brownson
BTDT. I learned long ago from a near-miss on an injury to clear my tabletop before turning on the saw. Put stuff you're going to run past the blade on an adjoining surface OR, as you note, on the floor.
Re: Whoa! Vertigo??
Just for a minute....
I thought I was having a seizure....
You are right, if that had fallen on me it could have been a disaster. And if it just fell over it would have surely done some damage.
Re: Whoa! Vertigo??
Re: Whoa!  Vertigo??
Joseph Mulherin
Barry, with all your knowledge of building other homes and remodeling others, make yourself a plan on constructing an add-on to your shop to give yourself more room to work.....say 24' x 18'.
You have the wood, trees, just need the concrete.
Re: Whoa! Vertigo??
alternative plan
They are called saw horses. They are used to support 100 bd ft of lumber so it doesn't shear off the cast iron table saw wing held on by small brittle flanges, which is worse than the saw tipping over.
Re: Whoa! Vertigo??
You are Correct, Sir!
Re: Whoa! Vertigo??
Re: You are Correct, Sir!
Joseph Mulherin
Barry, those horses are fine until it snows or rains onto your farm until it snows or rains and you still want to work on something. But, with an additional building added you can work in merryment in quiet and warm facility.
