Fixed my Dewalt Planer - Finally
Bart S Goldberg
Thought I'd share a story about my recent experience in trying to fix my Dewalt DW735 Planer. Several years ago, I decided to upgrade my planer with a Byrd Shelix cutter head. I did this before there were any Youtube videos showing me how to do this. I did have some help. My friend Dave Pollack, a professional woodworker, help me with the upgrade.
After we were done, we have some left over parts. Not a good sign, i know. But the planer was working and continued to work for several years. However, it was very noisy.
Just recently, I started having problems with the drive belt falling off. First time it happened, I just reinstalled it. 2nd time it happened, I decided to take a closer look at why it kept falling off.
I noticed that the cuttterhead pulley was very loose on the shaft. It could move almost a 1/4 inch side to side. Not good. I removed the nut and the pulley from the cutterhead shaft, and realized that there was something missing. For the cutterhead pulley to be in alignment with the drive pulley, it had to be shimmed to the outside of its moveable range.
I then go online and search and find a video of someone installing a new cutterhead on my model of planer, and got so see what the pulley arrangement should look like. Its then that I realize I am missing a spacer.
I had kept all the left over parts from my upgrade and lo and behold, I found that missing spacer. I installed it yesterday, and now the planer works great, and is alot less noisy.
Re: Fixed my Dewalt Planer - Finally
AZ in Colorado Springs
Good for you!! Nice to hear about a success story. Happy endings and great.
I have the older two knife version of the Dewalt planer. Two or three years ago I started to get lines across the wood sort of like snipe, but more random. The early inspection revealed what looked like a stretched drive chain. Tore into it and found the bearing blocks were worn and some of them were wallowed out. Sort of surprised to find they some sort of graphite or other composite and not ball bearings. Replaced them and the chain ans all is well.
Saw an YouTube bit on a guy tearing into his machine for the same problem. He was sure it was some other problem. Filmed the whole process in two parts and finally admitted he was completely wrong and he had the same problem I had. Can't believe he left wrong stuff out there.
How do you like the new cutter head? Glad you got your problem fixed. Now you have more storage room , having put that pesky left over part in it's right place. I am considering putting a similar head in my machine, but there is some discussion that the spiral head is harder on the bearings and having a ten year old machine and already replacing the bearings once, not sure its a good idea. May just buy a new machine with the head already in it. What do you think?
Bruce, a MN Galoot
Long ago, maybe 70 years or so, I had a great uncle who did some repair work on his B John Deere. When he put it back together, he had parts left over and since the tractor ran, he sold them.
