OT Gun "Bluing" options
Alan Young
Alan Young
Back in my college days I made several chess sets from steel. The original finish was done with gun bluing for the dark sets and zinc plating for the light sets. I was working for my dad's manufacture company at the time and they routinely sent of batches of parts to be plated- I just sent my pieces along when they were ready.....Years past and they were left in a box that was submerged in flood waters- the sets suffered a lot of rust damage. I re-turned them then painted them with enamel. I gave a set to each of my sons a few years ago when the graduated from college.
The enamel looks good over the steel but the finish does have a couple chips. I can re-coat these as I am nearby- But I have received a request for a new set. This will end up in the UK- I'd like to have a finish that will hold up longer so I am thinking of going back to the gun bluing...I'd like to have a nice complementary finish for the light pieces that doesn't employ the zinc plating because I am not anywhere close to Dad's plating arrangement and the overall look wasn't as refined as I want to match the gun blue. I may well just make the other set from Brass-but I am wondering if there is any type of "gun blue" solution that produces a lighter toned finish that can be done by an individual?
Thanks-Alan
Re: OT Gun "Bluing" options
Can't Help with the Chemistry
But suggest you consider plating for color. Chrome, if course, is an option, but copper would age beautifully with use as it takes on a natural patina. You'll find metal plating outfits in the yellow pages.
Dick Coers
powder coating is extremely tough. You can buy hobby setups and bake in an old oven. Clear over brushed steel, clear over bluing on the other side.
John McGaw
There are a number of different conversion coatings for ferrous metals that produce colors from shiny mirror to dead black but I don't know if any of the chemistry is suitable for do-it-yourself application.
Alan Young
Thanks Mark and Dick-already finding
Alan Young
Powder Coating and Plating services nearby!
Rick W
There is a process called "Cerakote" that a lot of guns get finished with these days. It can be a do-it-yourself process, or you can have it done by a gun shop or an individual.It comes in a wide range of colors.
Rick W
BrianMonumentCO
As a retired gunsmith, I can tell you that blueing (That is the correct spelling) is really a form of rust.
Most if not all blueing creates a blue to black coloring. There is a rust treatment that creates a brown finish. BUT for blueing the material to be treated MUST be a form of steel ie based upon IRON. It does not work on other metals. In fact some hot blueing will DISSOLVE brass and aluminum.
There are some easier cold blueing methods that can be done with good results that are less exhausting.
Painting of some type may ultimately be your best bet.
This may Include powder coating and baking.
You might want to check out www.brownells.com they are the largest gunsmithing supply company.
There are specific treatments for giving aluminum a dark finish like blueing.
Most treatments including blueing and parkerizing are immersion based. This means that the surface to be treated must be complete. IE covering totally with ZERO openings.
But gunsmithing and chess piece treatments may/are very different.
Two fairly easy ones
John in NM
First you can do yourself, rust bluing. Might be a bit of a pain with chessmen, as you have to buff with steel wool at one point.
Second you can look around for a gunsmith with a hot bluing setup. There are quite a few around.
Less easy, you can find a plating shop that will do nitride finish. This is a passivation process like bluing but vastly more durable. Comes out a dull black color rather than the bluish color of iron oxide. Like bluing it only works with steel parts.
Super easy, make them from aluminum and have them hard anodized. This is a much thicker version of anodizing and is usually only dyed black as opposed to any color you like. Like nitriding, it is an extremely durable finish, much more so than bluing.
Re: OT Gun "Bluing" options *LINK*
Keith Newton
I once had a great site linked for metal patinas for artist and metal sculptures, but couldn't find it, but here are one similar that I haven't used.
but gee,,,,,, couldn't you use something like ebony and maybe bloodwood or another cool exotic that would be really rich and easier to work?
http://www.sculptnouveau.com
Re: "yellow pages"   ???
Still around...,
Mark Nowicki
...yp.com, canada411.ca are two versions I can think off the top of my head.
Information organised by category and location is still a useful concept, probably more so today.
We Get
two versions dropped off by the phone companies every year; one for tri-county coverage and one for our "region" (Central Jersey).
Re: We Get
AZ in Colorado Springs
It's been about three years since we received a paper phone book.
Dale Warder
You might consider nickel plating. Caswell sells home plating supplies and kits. They seem to produce an acceptable job.
God luck
Book of metal coloring
Gary Smyth
The Colouring, Bronzing and Patination of Metals Richard Hughes and Michael Rowe, /Watsson Guptill, Publications 371 pages.
Not inexpensive. But has good color plates and hundreds of pages of recipes.
16 color plates
Chapter on techniques with a few illustrations
My best advice is to find a gunsmith and send it out. Bluing is often blotchy if not familiar with the art.
Re: OT Gun "Bluing" (poor) option
As a retired engineer and a firearm collector, I would not even consider "gun bluing" as an option for chess pieces! As Brian has stated, gun bluing is actually a rust coating, it only provides protection from actual iron oxide (red rust) when it is oiled. the bluing is porous enough to allow the oil to fill the pores of the bluing and prevent oxygen from penetrating to the iron of the gun barrel.
If the oil is not re-applied after handling (like playing with the chess pieces), enough oil will be removed to allow rust to begin. I would look at powder coating, painting with Cerakote, or a metal passivation treatment.
BrianMonumentCO
Good point Larry. More important for the issues of chess pieces is that chess pieces are handled by hands that can literally cause RUST. Certain peoples body chemistry causes steel to rust.
So even if the steel is blued it must be kept oiled which is messy for chess pieces.
kruizen
I just made a shorter version of a Oneway Vari-Grind jig. I used Caswell plating Black Oxide kit on it. So you can see the difference between commercially applied finish on the original and the Caswell finish on the shorter version. It was very easy an it only took 10 minutes from start to finish. So the Caswell kit comes with a penetrating oil finish which I used because it will get banged around some. For a chess set I would recommend just ordering a pint of the chemical for about 30 bucks and put a coat of rattle can lacquer on it. I think would be able to get by with one coat for rust protection an still keep the definition with out getting the finish to thick which would make it more susceptible to chipping.
There are several YouTube videos on the black oxide finish which I watched before ordering.
