Motor Wiring Problem
TomD
My milling machine with 110v 1/2hp motor stopped working when a short appeared in the barrel switch. This switch allows the motor to be turned on so that it operates in forward or reverse direction. Odd for a machine that is basically a router (from the wood perspective). These switches are common on many machines.
When I opened the switch I found that it was tightly packed with wires, and the white lead from the motor appeared to have arced. It was not clear whether it was once attached to the switch, or whether it was heavily wrapped in tape to stop it from making contact. The switch contained the four wires from the motor: red, black,white, green. And also the 3 wires from the line: Black, white, green. The green wires were bolted to the frame of the switch and machine.
I had difficulty deciding what connections the switch was designed to make since I neither new the secret to motor reversing, and the switch was damage to the extent I was not sure what the connections had been.
At the moment I am only interested in rigging the motor to run forward using a simple switch. Forward is clockwise when viewed from the end of the shaft.
Decoding the switch I think this is the wiring for clockwise rotation: Black motor to Black line; Red motor to Neutral line
With Neutral motor either connected to line Neutral (and red motor), or not, when switched on, the motor hums but doesn't start.
Seems that maybe along the line the capacitor start circuit has failed.
The motor is an old Delco that looks superficially fine, the same vintage as the machine, and it's wiring plate has a dozen wires on it and is too complex (not to mention partially hidden by a wall) to get much of use from it.
Anyone have a suggestion before I pull the motor out and rig the Mill with a variable DC motor I have lying around?
Re: Motor Wiring Problem
Keith Newton
It's hard to say without seeing in there, but from your second paragraph, I'll take a stab at it.
I don't think the white neutral wire needed to run through the switch contacts, so if that was the problem, just try to repair it.
In the barrel switch, normally the hot would be under the contacts which go straight through the switch the same whether in For, or Rev.
As for the others, the two wires which need to be switched for F & R should be under the motor cover, or nameplate. If you think the capacitor is fried, just take it to a motor shop, where they can test it and provide a new one for maybe $10
Ralph Lipeles
Motors that I am familiar with have a starting winding and a running winding. Direction reversal is accomplished by interchanging the 2 leads on either winding. I'v don it with a double pole, double throw, toggle switch.
Dick Coers
I would definitely NOT put on a variable DC motor. A mill needs high torque, low speed. Just the exact opposite characteristics of a DC motor with a variable speed pot. I've never run a mill that didn't have a reversing switch.
